JW Apostate
trekkor's Avatar
Why do trailer tires fail?
Face it, they fail early and often.
What gives?
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 11-05-2010, 10:03 PM
slodave's Avatar
Snow tires.
Old 11-05-2010, 10:10 PM
JW Apostate
trekkor's Avatar
Sunnavah...
KT
'01 Boxster
Old 11-05-2010, 10:16 PM
my guess would be some combination of heat, load, and design
Chris
the more i learn, the less i know
Old 11-05-2010, 10:23 PM
Oracle's Avatar
Cheap and crappy materials. Those with real car wheels are much-much better.
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 11-05-2010, 10:35 PM
crustychief's Avatar
A couple of weeks ago I took out a new to me 5th wheel trailer and was concerned about the heat on the tires. made it there but had three blow outs on the way home. the same thing happened to me on my 944 that used to sit a lot, I autocrossed it one day, four flat tires that evening. Old tires+heat cycling= junk tires.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 11-05-2010, 10:41 PM
We run trailer rated tires and religiously check pressures. We have cut blowouts down dramatically and we run at least several hundred miles a week pulling a trailer of some flavor.
Old 11-05-2010, 11:13 PM
pete3799's Avatar
Cheap tires,low air pressure,too much weight.
Pete
79 911SC RoW
Old 11-06-2010, 05:08 AM
canna change law physics
red-beard's Avatar
Go get some larger, higher rated tires, if they will fit. I did this for my utility trailer and never had a blow out since.
James
Red-beard for President, 2020
Old 11-06-2010, 05:38 AM
IROC's Avatar
Tires need to be used on a regular basis. The act of rolling under load protects the tires from ozone damage, etc. Tires that sit for extended periods aren't going to fare nearly as well as tires used constantly.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 11-06-2010, 05:40 AM
MAGA
Tim Hancock's Avatar
Heat which is generated by running low tire pressures is the usual culprit. Most folks do not think to check their seldom used trailer tire presures.... I do EVERY time I use a trailer.
I run 80 psi in my homebuilt double JetSki trailer tires which are loaded within 50 lbs of the max weight rating. When I first used this setup at highway speeds on a 90 degree summer day, I stopped often to check tire temps with a digital thermometer... temps never climbed above about 100 degrees.
This particular set of tires were left overs I brought from work 15 years ago when we built a custom tire mounting machine for a customer. They had been been in my attic for over 10 years before I put them into service several years ago on my JetSki trailer. They will not get replaced until they show signs of dry rot cracking on the sidewalls.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 11-06-2010, 05:58 AM
white85carrera's Avatar
Tire pressure. Tire Pressure. Tire Pressure.
Jim
'85 911 Carrera-#008
'23 GMC 2500 AT4
_________________
Old 11-06-2010, 06:08 AM
pete3799's Avatar
On the subject of tires....
I checked the mileage on my Peterbilt drive tires on the way back from Ga. the other day.
320K + and i think i'll make it thru another winter on them. I check pressure regularly,
have rotated them 3 times. I run Michelin's on truck and trailer (have for 25+ years)
They're pricey (over $400 a piece) but worth it in the long run.
Pete
79 911SC RoW
Old 11-06-2010, 06:57 AM
Non Compos Mentis
Most trailers sitting on the side of the road because of a failure have those tiny 12" or 13" wheels. They have to spin so much faster than the tow vehicle's wheels that the bearings also get overheated. Between hot bearings and underinflated tires, trouble is to be expected.
Old 11-06-2010, 07:29 AM
Platinum Member
dad911's Avatar
+1 on Tire pressure. Also curb rash is higher on trailers, as are the side loads when turning a trailer backing up. In my experience, if 1 tire blows on a multi-axle trailer(loaded), the remaining tire is overloaded, and I have found its life greatly reduced.
Old 11-06-2010, 07:57 AM
Tire pressure + infrequent use = bad combo
'87 924S (Sold)
Old 11-06-2010, 07:59 AM
Yup. And bearings that get dipped in salt water down a boat ramp and are never cared for. I am amazed at the big heavy things that get hauled on little trailers..
Old 11-06-2010, 08:24 AM
Z-man's Avatar
- Tire pressue
- Dry rot (for those who don't use their trailer more than 2-3 times a year)
- UV damage due to extended exposure to sun. (Get those 20 dollar wheel covers you see on RV wheels)
- Extra weight due to load.
They will all affect tire life.
-Z-man.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 11-06-2010, 09:13 AM
Bill Verburg's Avatar
Tires need to be used on a regular basis. The act of rolling under load releases flex compounds into the rubber, w/o these released compounds dry rot and UV damage are accelerated.
add poor air pressure control to the list and they will fail prematurely.
tire treatments like 303 do help some but it's only a surface treatment, the internals still need regular exercise to keep them flexible
Bill Verburg
Old 11-06-2010, 11:19 AM
JW Apostate
trekkor's Avatar
Thanks for the thoughtful posts.
I use this trailer quite a bit and am good about checking the tire pressures.
Two to three trips a month.
The one up to this is America's Tire Company offers a six year replacement certificate on trailer tires as long as there is a certain tread depth left or the tire is less than six years old.
So, it's just a matter of rotating the new tires onto the trailer.
KT
'01 Boxster
Old 11-06-2010, 11:51 AM
