Trailer tires are made to withstand UV effects better than car/truck tires.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
With the exception of Michelin all trailer tires that I know of are made in China. I own 4 trailers ranging from 20' enclosed to 53' semi car transporter. The smaller tires( 15, 16, 17.5) that are made in China fail at a much higher rate so you have to watch them like a hawk. On a side note if you go to Goodyear's website they are adamant about not trailering over 70 However with my Duramax it's really hard to go that slow
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R |
RETIRED
Lots of trailers run close to or exceed their weight rating. Fail.
Trailers are left outside and tire walls deteriorate. Fail. Trailers hit curbs and other obstacles that the tow vehicle misses. Fail. Trailers get low maintenance, bearings heat up, run low pressure. Fail. Trailers get the tail end boogie, low pressure tires, wall failure. Fail.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
JW Apostate
I'll snap a picture of the tire that was caught just in time...
KT
'74 914-6 2.6 SS #746 '01 Boxster |
Detached Member
My tire guy says its a combination of all those things, especially sitting in one place for months at a time. I take the load off of my camping trailer tires by extending the scissor feet levelers to take the load off the tires.
Hugh |
Also, on a multi axle trailer the tires are "scrubbed" on turns instead of actually turning (not rolling).
Brent Early85 944 LM6Y Paint Code |
JW Apostate
![]() ![]() So close! KT
'74 914-6 2.6 SS #746 '01 Boxster Last edited by trekkor; 11-06-2010 at 04:45 PM.. |
Platinum Member
WAG but looks to me like shifted cord from pothole or other road debris?
More wear on edges from under-inflation? Center tread looks deeper in pics. |
underinflation
Chris the more i learn, the less i know |
Non Compos Mentis
Pshaw! That tire has lots of life left!
RETIRED
Might want to do like the racers do and check tires temps next time on the road. Hand held pyrometer will give edge and middle of the tire temps.
JW Apostate
Good idea.
I have the pyrometer. I've been good about tire pressure with these tires. That wear looks like it took some time, right? How long would it take to wear the shoulders if I drove on the tires under inflated? KT
RETIRED
Depends on how heavy a load and how twisty the road......
BTW, there are pressure gauges that send an alarm remotely to a receiver in the tow vehicle. I just got some new LT rated truck tires.....my pressure is 65psi. I flat out forgot they ran that high. Doubt the ex EVER checked them.....
" Formerly we suffered from crime. Today we suffer from laws" (55-120) Tacitus |
JW Apostate
Nope, 49.
Sidewall requires 50. KT
Man, something isnt right! the load isn't being carried by most of the tire!
Belt shifted. POS tire. What brand and where and when( both on the sidewall) was it built?
JW Apostate
OK..
I went out and looked again. This is a Carlisle brand trailer tire. 11th week of '08 build date. ( 1108 ) Upon further inspection the psi is recommended at 65. The other three are 50. Could this happen over 120 miles? The distance I towed on Friday. KT
RETIRED
It doesn't take long....
Licensed User
PV=nRT
