-   -   Help AV Guys (http://forums.pelicanparts.com/showthread.php?t=576777)
126coupe 11-23-2010 01:58 PM
Help AV Guys
I want to play a slideshow on this tv from my mac book.
Any ideas?
Thanks in advancehttp://forums.pelicanparts.com/uploa...1290549499.jpg
http://forums.pelicanparts.com/uploa...1290549517.jpg
imcarthur 11-23-2010 02:17 PM
i am not a Mac guy but I believe you need an Apple adapter + a VGA male to female cable. It will plug into the DB-15 connector (the blue 15 pin one).
Ian
Edit: Correction: That would be male to male cable.
MysticLlama 11-23-2010 02:37 PM
Either that or one to HDMI should work, HDMI seems to figure out the resolution and center better than VGA usually.
LENELSA 11-23-2010 02:58 PM
Just burn a disc off your mac and play it with you DVD player.
scottmandue 11-23-2010 03:06 PM
I believe my buddy uses a mac adapter video out laptop > HDMI
126coupe 11-23-2010 03:42 PM
This mac does not burn DVD's
HHI944 11-23-2010 05:30 PM
I use the microDVI-hdmi adaptor to watch shows online, on my tv pretty frequently. The cable was something like $40 and all I had to do was select hdmi as the source on my tv...
Edit- pretty sure that era macbook is the mini DVI port, so any miniDVI - (Whatever method you choose) cable will work, the mac should automatically pick it up and do it's job.
