Almost Banned Once
How do I fix this?
PLASTIC Headlights on a Merc!
![]() Is it possible to buff these back to clear or do I need to buy new ones? I know I can get a kit with the polish and stuff to fix plastic headlights... But has anybody done this to Merc Headlights? ![]()
- Peter |
I used the kit on my Land Rover. I was pretty satisfied with the results considering replacement costs.
Or you could just get some 2000 grit wet or dry sandpaper and work your way up to a fine cutting compound followed by some plastic polish.
A nose heavy airplane flies poorly, a tail heavy plane flies once. Last edited by crustychief; 01-24-2011 at 10:07 PM.. |
unless you pull the headlights to do it, be sure to tape the edges. if you're buffing them, you will burn through clearcoat in about .2 seconds
edit: i would do it by hand. forget the makita
-mike |
a.k.a. G-man
I have the same problem with my VW, though not this bad.
Is there any way to prevent it from dulling again or protect the lenses afterwards too? (sorry, not meaning to hijack)
Сидеть, ложь, Переворачиваться |
Run smooth, run fast
Peter, what you have is a Benz, not a Merc.
If you had one of these, you'd have a Merc: ![]() ![]() ![]()
- John "We had a band powerful enough to turn goat piss into gasoline." Last edited by Heel n Toe; 01-24-2011 at 10:34 PM.. |
Almost Banned Once
Maybe a standard two pack clear coat would work...
- Peter |
Almost Banned Once
- Peter |
3M Headlight Restoration kit gets good reviews. I need to do the job on the bimmer soon. Some people paint the headlights with clear right after it's been restored with good results, I think I'll just leave mine and repolish in a few years if the need be. Or you can keep it shiny with the Maguires Plast-X.
83 911SC Targa Everything I say is my personal opinion, and has nothing to do with my team. |
the headlight restoration kits work just fine in most cases.
iv run across a few that had to be sanded iv done around 15 pairs and only one was beyond repair
86 carrera coupe, track & daily driver. 7 other unimportant cars (mostly VW's) 1 very cool dog. RIP my friend no kids, no wife, HELL YEAH. |
I have used plastic buffing compound on a stand up buffer and its the best
Almost Banned Once
The car belongs to a girl I've been dating for about 6 months so I want it to look perfect when I'm done.
- Peter |
be very gentle as the buffing wheels like to burn plastic.
very light pressure if any at all and it should be fine
I have used the kit with the sandpaper, and 3 different grade polish with good results, however, I recently ran out, and used a generic product that I got from the local Advance auto parts. It is a one part product, and does not require any buffing or sandpaper. Use it like wax/polish. Easy on, easy off. It works excellent, and is super easy. I cannot remember the name right now, I will look at it when I get to the shop this am , and post it up later.
No left turn un stoned |
MAGA
I have always just used a 3M buffing compound (which pretty much works for anything from plastic to paint to aluminum) both by hand and by machine.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
New kid in town
I did our Toyota's headlights with the 3M kit and they came out great!
http://forums.pelicanparts.com/off-topic-discussions/555279-how-polish-plastic-headlights.html
I wish I still had 9111113443... Last edited by 71T Targa; 01-25-2011 at 08:17 AM.. Reason: typo |
Pre Registered
You need a proper speed drill, and its a little disconcerting when you first grind down the lenses to a completely opaque white, but the end results are pretty good. 30 minutes and about $15US, as I recall. Tim |
I just used the Maguires kit and it worked awsome. $24.99 at your local auto parts store. It comes with the sanding stuff, a buffer, and the polish.
1976 911/S/SC/BASTARD Mid9 Member #12 |
Seldom Seen Member
I wet sand with 800, 1200 and 2000 grit. Couple bucks and like new.
Why do things that happen to white trash always happen to me? Got nachos? |
Senior Member
I grew up in a 1950 Merc two door coupe. Three on the tree with a flathead V-8, never should have sold that car!
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
I used the 3M kit and it worked good but I'll be darned if the foam pad was wrecked when it got caught in one if those headlight nubs. It was worthless after that. Either cut them down smooth or be very careful around them.
