Team California
Need quick help with epoxy/welding problem:
I'm at yet another impasse with the 356, the engine is now ready to go in save for this little problem with the heater boxes. I've let this one go until now because I was busy with other things but now I need to solve it or install them with no working heat and deal w/ it later. (They were not previously working).
Basically, I need to attach this shaft to its flap/valve while it's installed in the HB. I took it to my welder and he could not assure me that his MIG welder would not warp/melt the flap even with a small/quick tack weld. The factory somehow crimped these on with a tiny weld, you can see the marks on the shaft and flap. I either need to drill tiny holes in both parts and find small screws and/or use some super-duper epoxy that is heat-resistent to attach the parts together. I don't know my epoxy products and this would be a 1-shot deal, ie. if it does not work, the part would be really mucked-up. New heater boxes are available for ~$300 each but need to be shipped. I need to install the motor today and would love to fix this box cheaply. Thanks in advance as always. ![]() Here is the offending part:
Denis |
abides.
Know anyone with a spot welder?
Graham 1984 Carrera Targa |
Detached Member
If you won't be able to get at it again easily, I'd drill, tap and machine screw with lock washer and high tensile strength (2 hour) epoxy.
Hugh |
JB Weld will work, as with all epoxy, surface prep is everything.
Tru6 Restoration & Design |
If it has to go today, JB Weld is fine...how hard is it to get to later?
1996 FJ80. |
Team California
Is JB weld really heat-resistent? (Never used it).
Denis |
Team California
Any work involving heat exchangers is an engine drop + exhaust removal. Which is not the end of the world on these cars but it would be nice to fix this one before installing. The HE on the other side is junk so the engine is coming out again either way but I could at least have heat on one side.
Denis |
Team California
Denis |
Control Group
what about drilling through it and rivet together, or grind a flat spot on shaft and use a punch to get flap in close approximation to flat spot
How different is that piece from a bug of similar vintage?
She was the kindest person I ever met |
What about drilling a hole through the shaft/flap and using a cotter pin?
Eric 83 911SC/83 944 bunch of Honda 750s 69 Chevrolet C-20 Longhorn (family heirloom) |
MAGA
If you need to weld the flap to the shaft, I would simply drill a couple small holes in the flap where the original crimp indentations are and then I would simply rosette weld them with the tig welder..... Very simple IMO...
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Detached Member
Drill and cotter pin then, don't trust the epoxy in torsion.
Hugh |
Senior Member
Sure sounds possible. Maybe I'm missing something. Most if not all the above suggestions are excellent. What's so hard about drilling through both pieces and driving an interference-fit pin in there? Or as Tim says, open a couple of little ports in the sheet metal, and weld there. If the engine and exhaust will need to come out eventually, then you lose nothing with the gamble. Worst case scenario: The sheet metal gets a bit warped.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Un Chien Andalusia
I'd drill a small hole through the flap and the shaft and pin the two together. Possibly two small holes, one on each of the flats. Alternatively, do as Graham suggested and find someone with a spot welder.
2002 996 Carrera - Seal Grey (Daily Driver / Track Car) 1964 Morris Mini - Former Finnish Rally Car 1987 911 Carrera Coupe - Carmine Red - SOLD :-( 1998 986 Boxster - Black - SOLD 1984 944 - Red - SOLD |
THIS IS THE WAY TO DO IT. There won't be any warping problems. Short of this, epoxy the shaft to the flap. The problem with that is getting enough epoxy between the sheet metal and the shaft.
MAGA
Rosette weld..... I promise it will work perfectly and is the easiest/quickest way to get the job done right. (unless of course you have a specially configured tongs for your spot welder that can fit inside the heat exchanger opening and still squeeze/weld the parts together)
Senior Member
Spot welding is what I would use. Gotta be someone around with one. I have a small one from HF that I use...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
It was swedged on to begin with. That might be an option, just deform the hole in the plate so badly that you have to hammer the shaft through it. Inelegant, yes, but it would work just fine. I would probably do just that if it was mine, but Tim's suggestion is the best permanent, fool proof solution.
In the shop at Pelican
1996 FJ80. |
