-   -   Plumbing question... help! (http://forums.pelicanparts.com/showthread.php?t=594298)
aways 02-28-2011 12:49 PM
Originally Posted by DAEpperson (Post 5873630)
This thread reminds me of the one about BBS advice on changing a light bulb :)
That said, I'd use a Crescent wrench!
Thanks. I'm just being extra careful now, so I won't end up having to post more embarrassing questions later on...
daepp 02-28-2011 01:25 PM
Not picking on you - just picking on us (men) in general. And BTW - I love this stupid BBS.
Bill Verburg 02-28-2011 02:03 PM
2 reasonably large Crescents will certainly work well on the union, but not on the pipe.
to remove the union from the pipe will require a crescent and a pipe wrench or 2 pipe wrench's, w/ the possibility that vice grip might work on the pipe too.
lastly the cap will probably need to be tightened w/ a pipe wrench too
Superman 02-28-2011 02:21 PM
I'd prolly unscrew that fitting, and screw a cap on. Job duration: At least two beers (I drink much faster than I screw).
aways 02-28-2011 02:35 PM
Thanks all! I'll let you know how it turns out...
trekkor 02-28-2011 02:41 PM
Get video!
KT
A930Rocket 02-28-2011 03:50 PM
Borrow or buy that 2nd pipewrench if it's a bear to get in there to remove/install it. You don't want to have to go in there twice and you'll always need it later.
911boost 02-28-2011 04:01 PM
If you have a crescent big enough to turn the female side of the union (the larger one), and a crescent on the smaller side (the side you can see the pipe dope, or threads that the female "nut" of the union attaches too), you should not even need a pipe wrench at all.
You may even be able to find a cap to fit over the male end of the union, so that you don't have to take the union off the pipe. That would be the best and easiest solution.
Bill
RoninLB 02-28-2011 04:03 PM
the coupling may feel like it's a little seized when you feel your sack tightening up
if so i usually have a 2# baby sledge handy to whack the outer large female part of the coupling
sometimes I'll whack it while applying torque
2' pipe wrenches will be handy and can take another 2' length pipe slipped over the handle if necessary for leverage
plumbers don't follow torque specs when installing so be ready for tight
911boost 02-28-2011 04:06 PM
I agree with Ronin. If you don't need the pipe after you get done, keep a piece of it, it works great for slipping over the handle of a smaller socket wrench for when you need to get a really tight nut or bolt off.
It also works well for killing Col Mustard in the Library....
gr8fl4porsche 02-28-2011 04:08 PM
+1 on being tight. Lots of torque by the installer, dried pipe dope and corrosion will most likely laugh at your crescent wrench.
Crawling under the house with a crescent wrench will likely result in another trip back down with the proper tools.
Zeke 02-28-2011 04:50 PM
If you buy a pipe wrench, get this one:
http://t1.gstatic.com/images?q=tbn:A...SU1fuQPBSSGSTV
I don't know why, but the dynamics of the thing seem to grip better than the standard configuration. And, of course, it works well right up to wall.
cgarr 02-28-2011 05:15 PM
Is that pipe a long run that your gong to cap? If so you might want to remove it back to the next water supply pipe and cap it there. That long run uncirculated would be a lot of "standing" water in that pipe that never gets flushed and can grow lots of nasty things in it over time.
aways 02-28-2011 06:07 PM
Hmmm. Thanks. It's about 3 or 4 feet. I was thinking that there might be enough turbulence in the system as a whole so that the water in this section will slowly diffuse and circulate... I also drain the pipes rather frequently when we're away in winter, so the standing water will be flushed out then.
wdfifteen 02-28-2011 06:33 PM
Originally Posted by trekkor (Post 5873988)
Get video!
KT
Yes! Video of a girl in a bikini holding whichever of the 39 tools that have been recommended to do this job that you actually used, if any. You my want to look up an old Rigid pipe wrench calendar for inspiration.
jyl 02-28-2011 09:51 PM
I'm surprised you guys would do this job without a sawzall. I was under the impression that any job worth doing is worth firing up the sawzall for. It's the funnest power tool ever invented (that isn't bought in a sex shop).
GH85Carrera 03-01-2011 05:52 AM
Using a saw will make it necessary to bring a pipe threader for the cut end of the pipe. That is something most guys don't have. Of course that is a reason to go buy some tools. We all need more tools.
cbush 03-01-2011 06:54 AM
I wondered how that was done--so I googled it. Having a racheted threading kit for buried pipes that you have to cut and replace pieces of would be very helpful! I had only seen the large machines in places like Home Depot.
Great advice!
GH85Carrera 03-01-2011 07:14 AM
I actually have a pip threader for 1/2 & 3/4 inch pipe. I have used it just once. I did not have to buy it, I inherited it from my grandfather 25 years ago.
It is a lot of work to use.
Zeke 03-01-2011 08:02 AM
Great advice!
I've got that same set. They need a pipe vise as well to use. There is a small version of the electric threader now that will work in even closer spaces.
