AutoBahned
RWebb's Avatar
PV Solar Power
someone asked for a thread...
Here is a post copied from the nuke radiation thread:
Originally Posted by red-beard View Post
[PV Solar] is not cost effective [currently, except in unusually remote locations.] We need to reduce the cost of Solar PV by a factor of 10. This is not going to come from manufacturing efficiencies, or even low labor costs (China). It is going to come from some break through in manufacturing.
Amorphous is the only technology which looks promising. There may have been a break through recently. It is already 1/2 the cost of mono-crystalline. With the reduction of the Staebler-Wronski effect, panel ratings will be 25% higher for the same size. This gets you down to 40% of mono-crystalline. This needs to cut it in half again, or more, to compete with carbon based fuels.
Thoughts on thin-film?
Old 03-23-2011, 06:27 PM
winter-hater club member
nynor's Avatar
pollution and cost?
"COOL PRIUS!" - Nobody Ever
Old 03-23-2011, 06:31 PM
304065's Avatar
cant get it below a buck a watt with the present technology
best way to approach a buck a watt is with low cost manufacturing-- but even the Chinese cannot get to that level (and their QC and "guy with a soldering iron" approach are incompatible with offering the 30 year warranty required by the market)
there are other approaches
pick the right one and you'll be reading this from the back of a steam launch in Positano
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-23-2011, 07:17 PM
abit off center
cgarr's Avatar
Producing Power at night now that's interesting!
______________________
Craig
G2Performance
Old 03-23-2011, 07:28 PM
Unconstitutional Patriot
turbo6bar's Avatar
Cheaper, but consumes more area.
The prices are continually coming down. The cheapest grid-tie kits are under $2/watt, and you still have to address mounting, labor, permits, and such.
Old 03-23-2011, 07:32 PM
canna change law physics
red-beard's Avatar
Amorphous is thin-film. It is cheaper, less efficient, but more cost effective. It suffers from Staebler-Wronski effect, a loss of 15-25% of the power production after 6 months. Ratings are usually from the stable point.
James
Red-beard for President, 2020
Old 03-23-2011, 07:36 PM
AutoBahned
RWebb's Avatar
pollution = very low
cost = high (maybe not so high when you add in all the real costs and subsidies for other forms of power)
Old 03-23-2011, 08:09 PM
AutoBahned
RWebb's Avatar
PV solar also can be done by installing it on rooftops -- this also shades the building so it requires less cooling (and solar is most useful in hot, sunny areas)
moreover, with a rooftop install you have nil transmissions losses (!)
an important security advantage is that PV solar (tho not concentrated sunlight (mirrors all over) solar) provides a distributed power supply -- if an earthquake, accident or terrorist attack (say esp. a cyber attack) zaps part of the grid then areas with PV solar will still have power - maybe just some, or maybe "even too much" - this is a significant adv. vis a vis risk
our power grid today is already failing and is far too susceptible to such security risks
the there is the "PR advantage" - nobody is scared of it
too bad it is (currently) so expensive
Old 03-23-2011, 08:13 PM
How well does it stand up to hail and high winds?
'87 924S (Sold)
Old 03-23-2011, 08:18 PM
AutoBahned
RWebb's Avatar
about the same as your windows do
Old 03-23-2011, 09:07 PM
nynor's Avatar
Originally Posted by RWebb;5920602[B
]pollution = very low[/B]
really? it is non-toxic to produce the stuff?
AutoBahned
RWebb's Avatar
pollution = very low as the toxicity to produce solar cells is ~~ same as to produce other commodity semi- chips; they use a water/detergent wash nowadays
Old 03-23-2011, 09:35 PM
Max Sluiter
Flieger's Avatar
Seems like solar thermal has better storage capability than photovoltaic- at least with molten salt.
I think the best storage would be pumped hydro, though. Use excess electricity to pump water to a high reservoir, then let it fall back through turbines when load is higher.
Old 03-23-2011, 11:19 PM
MAGA
Tim Hancock's Avatar
PV is way too expensive to be the answer for large scale power generation. Nuclear power is the only present viable large scale source of energy.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 03-24-2011, 05:15 AM
My windows are vertical my roof sure is not. One recent hail storm here destroyed tile and asphalt shingles and even the steel roof on our commercial building had some big dents. Granted those storms are uncommon but insurance companies will have to foot the bill for replacement or not many homeowners will take the risk of total loss.
Old 03-24-2011, 05:29 AM
Alter Ego Racing
ErVikingo's Avatar
I quoted a system for my new home and even with subsidies it will take over 40 years to break even (assuming no repairs are required and not considering insuring them).
I hope it takes off soon. Right now, the business case behind it relies on the subsidies.
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 03-24-2011, 05:50 AM
wdfifteen's Avatar
I was just there last week! A quaint place, but no steam launches that I saw. There was some old guy rowing out in the surf every morning checking some kind of fishing gear.
Old 03-24-2011, 06:05 AM
I have never looked into a system. I am curoius, I assume you have to do some occasional cleaning on them. Few roofs will last 40 years. Is the system set up so they can be removed to replace a roof, or does one just do all the work of full installation all over with a new roof?
I would have to assume that in the year 2031 the technology of the new cells would make your 20 year old cells from 2011 not worth reinstalling after a roof replacement.
Old 03-24-2011, 06:09 AM
Alter Ego Racing
ErVikingo's Avatar
Glen,
In my case they would be going over a concrete roof. The roof provides for attachment points which are considered on the structural engineering of the house. Especially in my hurricane prone zone.
On those “stubs” low profile aluminum racks are attached which hold the PV panel clusters/modules. They can be removed or better yet, tilted up for access to the underside or the roof.
Old 03-24-2011, 06:18 AM
Ok, I figured they had thought of a system to make removing or replacing a panel fairly simple.
Old 03-24-2011, 06:22 AM
