How to preserve rechargeable batteries?
I have a touchpanel system in my house, it controls most everything in the house. The problem I have is the batteries for the panels are now discontinued by Crestron. The solution from Crestron is to upgrade to a new panel, this however takes a huge effort to get a programmer out and change equipment and software.
What I did was buy up a few of these custom battery packs and I want to store them. They last about a year if you maintenance them correctly, so I purchased three more and I want to store them to be used in the next few years. Here are the specs: Quote:
![]() Do I freeze them? Keep them in a drawer? Refrigerate them? Put them in sealed containers? How can I keep these for future use?
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
canna change law physics
NiCd Battery Care and Storage
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
BTW, there are a lot of places which rebuild old battery packs with new Ni-Cad cells, just for your sort of problem.
If you still have one of the old packs try to take it apart. Most likely it is full of standard size ni-cad cells. Local battery stores usually have a guy to replace those cells. There is a local Interstate battery store that has rebuilt several of my cordless drill battery packs.
It is worth a try.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Jim, that's exactly what I'm looking for, thank you! Also I will start looking for a re builder, I had no idea these things could be opened up, they look like a solid sealed brick.
Senior Member
Have you tried at batteries plus to get them remade? They can usually put new cells in most battery packs.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
No, I never even considered it. I'm going to now. I've been shelling out a good amount of money for these things each year. I need two per year, and I do everything they say to do right down to the discharge process.
Platinum Member
Di-sect one of the old ones, let's see what's inside.
I'd bet on standard size cells. |
Yeah, what James/Joe said. Check out a "Batteries Plus" type place, and see if they can make one up. Ni-Cds are pretty old tech these days as well, so you might see if they could retro a Li-Ion (or similar) pack. At the very least I'd upgrade to better/higher capacity Ni-Cds. If you are handy with a multi-meter, soldering iron, and shrink tubing, it shouldn't be that hard to DIY it either.
OK, I got home tonight and decided to get crazy with this. I used a knife to open the case, it took about 30 mins of careful cutting. Below is what was inside:
![]() So from the sticker on the side of the battery they are "Metal hydride Rechargeable." And I think I get the batteries I need from the store and build a new pack. However... what is the raised diode looking item? I'm asking because when these fail, they die quick. So I'm wondering if this has something to do with it.
And I found the batteries:
http://www.batteryspace.com/nimhrechargeablecellcsize12v5000mahflattop15arate1 pc.aspx $5 I want to kick myself.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab Last edited by Scott R; 05-17-2011 at 06:06 PM.. |
Not 100% sure, but I am guessing the "raised diode looking item" is a thermistor to control the temp while charging, hence the 3rd (white) wire. If not, it may be a diode to regulate voltage going to the device/panel. |
NiMH are similiar to NiCad's. chemical difference. and voltage dropoff difference, but effectively same rechargeable 1.2V cell.
can't really tell from the picture w/o reference, but looks like a subC cell. there's some print on the middle of the cell. that'll prob show the size. BATTERIES AMERICA |
