PRE-H20's Avatar
MAF Sensor..... help
hey guys... are there any mercedes guys here?
i need to locate the MAF on a 2005 C230 Kompressor......
anyone?
here are pictures of the engine bay....... i know its in the area... just dont know what to look for or where... please point an arrow to it like you guys normally do.....
thanks....!!!
Old 07-12-2011, 03:45 PM
A930Rocket's Avatar
I'm going to say this is it.
Old 07-12-2011, 03:54 PM
I'm with Bill
Rick V's Avatar
The "screen thingie" that the air filter was hooked to with the flat bosch connector on it. Pic one is spot on
Old 07-12-2011, 03:55 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
The MAF sensor is in the first picture. Unscrew the sensor from the airbox.
Old 07-12-2011, 03:57 PM
A930Rocket's Avatar
I wanted to confirm my post and my search found your post on MB World.
Even the pix from 2007 are the same.
Old 07-12-2011, 03:58 PM
PRE-H20's Avatar
jared.... sorry to be a knucklehead but can you point an arrow to it.... so far there are three answers on this thread. an arrow to the MAF and the connector please.
i dont see a connector on the grill looking thingy.........
sorry guys im just a rookie on this stuff.......
Old 07-12-2011, 04:02 PM
PRE-H20's Avatar
a930rocket...
yup i just posted there... i JUST signed up there..... but i dont know anyone over there.... i trust you guys here alot more... been here since 2005 or so......
my bride to be a freaking out over her car and its idling funny..... so im trying to get some info on it..... looks like i inherited a bit of a headache fellas..... RRR.
Old 07-12-2011, 04:04 PM
I'm with Bill
Rick V's Avatar
Dewd, it doesn't get much more pointed out than right here. All 3 answers are correct
Old 07-12-2011, 04:17 PM
one of gods prototypes
bell's Avatar
the maff is the whole round part which air travels through......as was arrowed LOL
the plastic mesh screen is to keep debris from flying into it as they are VERY sensitive, don't get a drop of oil on it or it'll burn up.......the wire which is monitored probes down into the "tube" and connects to the plug.......
do not mess with it too much, it can't be cleaned......
Brought to you by Carl's Jr.
Old 07-12-2011, 04:23 PM
A930Rocket's Avatar
Can MAF cleaner be used? I've used it during tune ups, but not sure if it does any good.
Old 07-12-2011, 04:34 PM
I'm with Bill
Rick V's Avatar
It doesn't hurt, the best thing you can do is stay from oil type of filters (K&N) and keep the paper filters changed
Old 07-12-2011, 04:37 PM
bell's Avatar
i've never had any luck cleaning sensors, because once they start to fail and cause running problems the wire/sensor has already failed......
Old 07-12-2011, 04:57 PM
This is the MAF sensor.
Old 07-13-2011, 08:49 AM
PRE-H20's Avatar
thanks guys
thanks guys... even the smarties that have commented. much appreciated!
id rather ask some bonehead questions than take a chance and made a mistake or make things worse.
Old 07-13-2011, 09:02 AM
+1 for no luck cleaning.
Just replace it
Randy
'87 911 Targa
'17 Macan GTS
Old 07-13-2011, 09:21 AM
I also think you probably won't have much luck cleaning it.
Old 07-13-2011, 09:23 AM
You do not have permissi
john70t's Avatar
Just a question, but how was the determination made that it was a bad MAF?
There are a variety of things which could cause a bad idle, and the computer code only spits out what it thinks is wrong, not always what is actually causing that sensor to return data out-of-spec. For instance, there could be a vacuum leak after the manifold and the computer thinks the metered flow doesn't match the idle rpm, so it blames the MAF.
Not second guessing the situation, just putting it out there.
I'm a "parts guesser" myself so you don't want to make my mistakes..
Some high-end vehicles use a MAF and a MAP(manifold absolute pressure) sensor, I've been told. No knowledge of that model.
Old 07-13-2011, 12:31 PM
is it a surging idle, like going up and down? If so, it's a vacuum leak, not the MAF.
Old 07-13-2011, 12:58 PM
Unconstitutional Patriot
turbo6bar's Avatar
Vacuum leak would also show up as a high idle.
Old 07-13-2011, 01:04 PM
Do you have a CEL? The MAF typically will throw P0170 and P0173. You can remove it and spray the wire with CRC Mass Air Flow Sensor Cleaner. This might fix your problem but the if the MAF is bad it should throw the codes.
Mike
Old 07-14-2011, 03:20 PM
