I've had an oilless 20 gal Craftsman for 10-12 years & it was used when I got it.
I've used it to sand blast, paint cars, run tools....yada. It still makes 120psi. Still going like the Energized bunny.....getting to look kinda gnarly tho. Noisy sumbytch. To the right of the table saw. It don't get much love. ......
JPIII Early Boxster |
"intakexhaust suggested" works great. Thanks intakexhaust .
I did it tonight when changing oil. The only thing I complain about this task is the drain bolt is not pointing down, makes oil drain is very messy. The PO probably never change his oil; therefore, the oil is full of metal shave. I ran the compressor a tank full, then drained it again. Both took 20 oz of oil. In ajusting the PSI, there were two separate adjusters to adjust the max and the min (turn on the compressor when air comes down). Mine was at 90 PSI max, and min at 65 PSI. I adjusted it to max at 120 PSI and min at 75 PSI. I want to max it at 125 PSI but the whole machine shakes bad after 100 PSI so I got scared ![]() Quote:
Fat butt 911, 1987 |
Is this a place to start a conversation regarding getting the water out of the compressed air?
On my $100 used Craftsman (Devilbiss) 3hp, single stage, dual cylinder compressor I'm working on designing an after-cooler and inline water trap downstream of the tank. I was wondering why the water drops out when the temps are still above the local dew point. I think I found out why - the dew point rises with pressure. e.g. at 150psi the dew point is near 125F. This is why you can build a DIY aftercooler with drain and an inline water separator and it works to get very much of the water out. Do I have a point or am I off track? Or maybe no one cares, which is fine also. This was something I was curious about. BTW - I got the regular oil from HF and "flushed" my compressor, will probably do a final flush with synthetic oil.
Sold: 1989 3.2 coupe, 112k miles |
Hi guys,
This old compresser of mine was running for years (once in a while). Thanks everyone again. Yesterday it decided to stop. The electric motor made some eeee noise, but the wheel/belt didn't turn. Probably it got too hot. It ran again, after I helped turn the wheel by hand. But then it stopped again after couple mins. Then I checked oil, oil of the pump (the v-shape component), it is so low. Maybe this is the problem? Now, don't laugh, I can't remember which oil I used, even reading all the responses above. Can someone please tell me which of the oil I should use from the pic below? Thanks much in advance. This is my compressor: This is the oil I want to add: I think the oil I filled last time was 1 of these: I also have this at home now. Thanks much everyone.
Fat butt 911, 1987 Last edited by rnln; 03-25-2021 at 07:55 PM.. |
Somehow I feel like the 2-cycle engine oil was the one I put in there in the past, but don't know if that is correct.
his car...
Instead of investing in new air compressors and updating elec. to accommodate them (having 220 is nice but not always necessary in a home situation) in home shop, spend the money on cordless tools. Cordless impact, ratchet are used often when it comes to car repair, but I do understand the need for compressed air if sand blasting or an air chisel is needed. How often is the question? 200 bucks for an impact. 120 for an air ratchet will satisfy most your automotive needs. |
abides.
You local hardware store should have bottles of air compressor oil. Those you show may work, but are not the same thing.
Graham 1984 Carrera Targa |
abides.
Also, might as well drain out the oil that remains, I’m sure it is pretty nasty at this point.
I dipped the in a stick to look at the old oil, it looked pretty clean like new. Draining it is fine, but if I can remember which of these I put in the past, I can just add more now and be done with it.... hate things like this happen in the middle of the project.
Is there such a 2-cycle or 4-cycle for this pump's fluid/oil? I guess not? The reason I asked because reading back on old replies, but I guess it is for gas motor, which I don't have. My motor is electric. Am I right? Thanks guys. ..... I can't remember what did I use the 2-cycle engine oil (in the pic above) for if not this air compressor's pump. I think I will add it in tonight, temporarily for now and will drain out after couple weeks. If anyone can see that it will destroy my compressor, please stop me ![]() Thanks again. BTW, what "makes 2.5 gallons" means? Do they use this oil to mix with something else? I know that I didn't, because I never mix any oil/fluid in the past. I wish I have good memory....
Fat butt 911, 1987 Last edited by rnln; 03-26-2021 at 01:31 PM.. |
Just FYI, 2 stroke oil is normally mixed with gasoline and used in 2 stroke motors (some motorbikes, chainsaws, weedeaters, leaf blowers, etc...).
Any other purpose, like this compressor pump? I don't have anything that has 2 cycle motor that I can remember.
https://www.aircompressormachine.com/what-kind-of-oil-goes-in-an-air-compressor/
You do not have permissi
(from a brief search):
Parts and diagrams: https://www.matoemparts.com/#Parts_By_Category Quieting tweaks: https://airpsi.com/low-noise/how-to-quiet-an-air-compressor-6-noise-reduction-tips 60db 2.5gal 2.4cfm https://airpsi.com/low-noise/rolair-jc10-plus-trim-finishing-super-quiet-air-compressor/ 68db 8gal 2.4cfm https://www.campbellhausfeld.com/air-compressor-8-gallon-horizontal-quiet-dc080500.html 73db 20gal 4cfm https://www.homedepot.com/p/Husky-20-Gal-Vertical-Electric-Powered-Silent-Air-Compressor-3332013/311273546?MERCH=REC-_-pip_alternatives-_-300085154-_-311273546-_-N&
Meanwhile other things are still happening. |
Kessel run in 12 parsecs!
Crafts-man air compressors, I have 2, a small one and a large one..
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
Hi everyone,
I am about to dissect the pump but want to double check with you guys first to see if anyone know what the problem is. Some things seize and if there is an easy solution? Or bearings, pistons? Thanks everyone again. Here is how it is now, https://www.youtube.com/watch?v=X0_xYe3dG9o That noise is not me. It's the pump this makes me feel that the pistons/cylinders are fine. Maybe the bearings? I remember right before it became harder to turn, I was keeping it running for too long to adjust the max/min pressures. So, maybe I overheated some parts?
Fat butt 911, 1987 Last edited by rnln; 03-30-2021 at 01:17 AM.. |
I read someone mentioned the air filter need to be clean, otherwise it can cause this problem. Does anyone know where would I find it on the compressor? I looked around the unit and didn't see anything like a filter.
thanks in advance.
That is not a dirty filter problem.
Take the tubes off the heads and see if you are feeling compression, or bearing friction. It may just need to be run for a few minutes to loosen up if it has been sitting. Can the motor get it started?
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
