závodník 'X'
Agree with you posters going with the big old industrial compressors. Buying those maint. free clackers is all hot air, garbage and don't last. You mentioned using air drivers; I would suggest at least a 220v wired, big air tank, V-configured (2 or 4 cyl with a big flywheel pulley) and with that size, they are two stage. Run synthetic oil (Amsoil is excellent in compressors). Having around 14 CFM is really ideal for your bigger pneumatic drivers but also for spraying with HVLP guns.
Once you have that, spend the money in a quality filter set-up and regulator. Also, I've often noticed shops with all this fancy stuff and with a big compressor but they fail to utilize it for what it really can do! Don't buy cheap hoses with a small I.D. and that goes for the couplers too. You want that air volume, including for spraying. This is different than talking about pressure. Been there and still doing it - Cheers, Scott |
závodník 'X'
The oil level and fill is in the lower picture and facing you, in the middle of the crankcase are two plugs. The lower is drain and the upper is fill. If it has a little dip stick, use that but if not, fill to the bottom of that particular plug. Don't overfill. For the pressure, if you know your regulator is working and adjusted at the max but still not getting a full 100psi rating, pull the cover off of where the pressure SWITCH is. To find that, follow the electrical power lead from the motor and it may or may not be where the power on/off switch is, but its nearby. Once you find it, pull the cover and most likely it will have a screw with a nut for locking it down. If it has the locking nut, loosen it and crank the adjusting screw in a bit. DON't over adjust. Test run the compressor and you would be safe to set it for 125 psi. Secure that lock down nut (if it has it) and replace the cover. |
Thanks. I have 2 questions.
what type of oil to use? Does it matter or any grade? How often do you replace oil? Manufacture specification is 100 PSI max, is it safe to crank it up to 125 PSI if possible?
Fat butt 911, 1987 |
závodník 'X'
125 psi is OK. Snug the headbolts too. Out for the day and have fun in the shop |
Synthetic compressor oil if the compressor sees winter cold otherwise it won't turn over
for my act a 60 gallon / 5hp is just about good enough for home auto painting and impact guns the local Snap-On guy may have used compressors for cheap. Small body shops come and go quickly and the Snap-On guy reposes. It's how I got mine
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Since you said SAE 30, I guess mineral 5-30 is ok too?
Fat butt 911, 1987 Last edited by rnln; 12-29-2011 at 12:28 PM.. |
It is typically straight 30 non-detergent. Basically 'engine break-in' oil.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Is it something hard to get or I can get it at any autopart store like autozone?
i want one of those...
Location: formerly a grass shack in Hawaii, now Peoria, AZ
i think non detergent oils are easier to find at Home Depot/Lowes/home improvement stores where the lawnmowers and weed wackers are.
Jeff '72 911 T Targa widebody VTK #111385 http://www.911vtk.com |
ok, I got that at home, for the chain saw. Thanks all.
I go to a compressor shop for parts and compressor oil
závodník 'X'
Since were still on the topic, drain the tank often. Condensation builds rapidly in any environment due to the heat / cool cycle. |
I went to sears and found the SAE30, oil for air tool. The problem is that I don't know if mine old compressor (pics above) is 2 cycle or 4 cycle. They have diff. type of oil for those. Anyone know?
A couple of things to note. Is your compressor powered by an electric or gas motor ? If it's a gas motor I am 99.9% sure it will be a 4 cycle. The oil you found sounds like it is for air tools not the compressor. To my knowledge they are two different oils.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
19 years and 17k posts...
My friends who have compressors, love their old Craftsman models...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
it's electric.
Ok, so air tool oil is not air compressor oil. Got it. Lucky I decided to ask before purchase, save a trip to sears. When you guys says "straight 30", is SAE 30 = straight 30? I usually see SAE 30. Is the oil in the link below ok for my electric air compressor motor? It says "compressor oil" but there is no grade indicated. 32 fl. oz. Compressor Oil
Senior Member
The Harbor Freight oil is probably fine but, if it were me, I'd prolly get a bottle of synthetic. It won't take much oil to fill it. The air tool oil gets dribbled into the brass nipples on the air tools themselves. Before you hook the air to it, just dribble some air tool oil into the air connection on the tool. I am doing a clutch in a pickup truck right now. Using my ol' small, Craftsman compressor which I got used for cheap. It works great but only seems to go to about 80 psi. 125 psi would have worked MUCH better. I had to use a breaker bar on some fasteners that my air wrench would have loosened if my compressor were making 125 psi. I wouldn't hesitate to mod yours the way intakexhaust suggested. I'm considering looking to see if that mod can be done to mine. Compressors don't explode, BTW. 125 is not unsafe. It's just a matter of how much harder your motor and compressor mechanisms will have to work, and whether your air tools are sufficiently robust.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I used to use my brother Craftman one, oil less. it is lound. This one is oil feed with a belt driven = very quite. I got it of a garage sales for $50 bucks yehhaa. This is probably the only thing I scored from garage sales around here. I will do the intakeexhaust suggested too.
