"YOU CANT RACE A CAB."
p.s. even spraying wd-40 into a chamber and then swabbing it out or thinking you have swabbed it out is enough to allow it to migrate to primer and kill it.
if there are TROUT..........there are BEARS! |
This all goes back to those carbide sizing dies. When you set up the die in the press, you typically run the ram all the way up (with the shell holder on it) and screw the die down until it touches the shell holder, then back it off one turn. This is done so as to avoid breaking the carbide sizing ring in the bottom of the die. Unfortunately, it means the die cannot size the case all the way down to the rim. Most pistols and revolvers have loose enough chambers to where this does not matter. I've seen several Rugers, however, that are tight enough to cause problems with this. About the only cure is to have the chambers opened up on the offending firearm. Any gunsmith can do this in less time than it's taking me to type this. On a couple of tight single action Rugers I own, I use the screwdriver blade on my Swiss Army knife to lever them in the rest of the way. I stick it between the hinge on the loading gate and the rim and pry forward. You can't do that on a double action, so you will probably have to get the chambers opened up a bit.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
One other thought I forgot to mention - if you are over doing the crimp, the case can buldge slightly blow the crimp. This can also keep them from fully seating in the chamber.
