I don't know what to tell you about that because we don't use those boxes. We use IC cans doesn't matter what's up there in the attic. Its not worth the few bucks in saving, plus, they are screwed to the joist so it will never come off. You might be able to remove the lights and snake your hand in there and peel off the tape. Better yet, leave the hole and remove the light and vacuum out the insulation after its all done. Since they are remodel cans, it can be remove with ease. You gotta let the heat our somehow.
Old 11-24-2012, 02:04 PM
wdfifteen's Avatar
Originally Posted by HardDrive View Post
I thought this was about something very, very different.
LOL! Me too.
Old 11-24-2012, 02:26 PM
<insert witty title here>
Christien's Avatar
I'm just going to build a box around them. Seems like the simplest and most fool-proof solution. A measuring tape, some drywall or styrofoam, a cutting knife and some adhesive and I'll have it done in less than an hour.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 11-24-2012, 02:27 PM
beepbeep's Avatar
I assume insulation is mineral wool and as such, it's non-flamable
(otherwise, you couldn't have it on the attic )
What's the wattage? I have 20W pots and they need less of a inch (19mm) free space above them to be "legal".
If using 10W, they don't need free space or pots.
I think you'll be all right.
Thank you for your time,
Old 11-24-2012, 02:31 PM
disband
juanbenae's Avatar
Originally Posted by Christien View Post
seal off the attic for good.
how are you gunna get the pot out of the attic when it ready?
Old 11-24-2012, 03:31 PM
I think he meant no one goes in there unless it is absolutely necessary.
Old 11-24-2012, 04:21 PM
Christien's Avatar
Well, harvesting the pot would be absolutely necessary I think he was playing on the joke. Maybe we should call them cans, not pots...
Old 11-24-2012, 04:34 PM
siht, I completely missed that one.
Old 11-24-2012, 05:06 PM
DanielDudley's Avatar
You need to be careful, as some lights are designed to work in insulation, and some are not. They do have thermal limiters now, but you have to make sure the ones you buy are the ones you need to use.
Old 11-25-2012, 04:41 AM
It'll be legen-waitforit
stealthn's Avatar
Did you not get a permit? If not if anything happens your insurance won't cover anything.
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 11-25-2012, 07:59 AM
A permit for pot lights?
Old 11-25-2012, 09:15 AM
Hell Belcho
Nostril Cheese's Avatar
So did I.
Old 11-25-2012, 09:55 AM
stealthn's Avatar
If they are new wiring, then yes. Code will also dictate what you can and can't enclose
Bob James
18 Macan GTS
Old 11-25-2012, 10:53 AM
Senior Member
What? You do not smoke Can?
Old 11-25-2012, 01:23 PM
