I don't know what to tell you about that because we don't use those boxes. We use IC cans doesn't matter what's up there in the attic. Its not worth the few bucks in saving, plus, they are screwed to the joist so it will never come off. You might be able to remove the lights and snake your hand in there and peel off the tape. Better yet, leave the hole and remove the light and vacuum out the insulation after its all done. Since they are remodel cans, it can be remove with ease. You gotta let the heat our somehow.
LOL! Me too.
<insert witty title here>
I'm just going to build a box around them. Seems like the simplest and most fool-proof solution. A measuring tape, some drywall or styrofoam, a cutting knife and some adhesive and I'll have it done in less than an hour.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
I assume insulation is mineral wool and as such, it's non-flamable
(otherwise, you couldn't have it on the attic )What's the wattage? I have 20W pots and they need less of a inch (19mm) free space above them to be "legal". If using 10W, they don't need free space or pots. I think you'll be all right.
Thank you for your time, |
disband
how are you gunna get the pot out of the attic when it ready?
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
I think he meant no one goes in there unless it is absolutely necessary.
I think he was playing on the joke. Maybe we should call them cans, not pots...
siht, I completely missed that one.
You need to be careful, as some lights are designed to work in insulation, and some are not. They do have thermal limiters now, but you have to make sure the ones you buy are the ones you need to use.
It'll be legen-waitforit
Did you not get a permit? If not if anything happens your insurance won't cover anything.
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
A permit for pot lights?
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Hell Belcho
So did I.
Saved by the buoyancy of citrus. |
If they are new wiring, then yes. Code will also dictate what you can and can't enclose
Senior Member
What? You do not smoke Can?
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
