Picked this up of CL the other day... It's an Ibanez RG... I was getting a tinny / brass sound out of it with no low end to speak of... adjusted the pickups again and all is good... Now I just need to loose the strat tremolo bar and I will make this edge III tremolo a hardtail....
http://forums.pelicanparts.com/uploa...1354234860.jpg |
xD when I bought it I had no idea how loud 100w was, I would have been more than fin with the 75 or even the 30w.
I use it at home the majority of the time. It does have the power sponge feature which I usually just leave at the minimum and volume around 1 is loud enough to hear but you won't piss everyone else off... 3 and above I think my neighbors start to hate me. I'll think about it and let you know. Are those the inf3 & 4 pickups in that rg? I have the same in an rg of mine and they are awful, not a very good pup really killed that guitar for me. Swap them out for something that will scream! |
I can't confirm this but I was told there a very few guitar string manufactures (D'Addari being the big one) and they make strings for the other companies.
And yes 100 watts should be plenty unless you are going to play heavy metal. :D |
Do they even make anything above 100w other than the Peavey 6505, formerly 5150, which are 120w? If you want much more than that, you can get into power amps and variacs, but I can't imagine a real use for it. 100w is more than you could ever use.
Elixer string. I run them on my Martin OM21 and they last a long time. Yes, more expensive but they will sound good forever and feel smooth. http://www.juststrings.com/elx-16027.html
100W 2-12 is overkill for almost every situation. I gigged for years with 22W 1-12 amps. Almost every guitard I play with is too loud and doesn't understand the basics. Here's my short list: 1. Don't play your music for your ankles. Either put the cabinet on a chair or angle it towards your head. Most people are way too loud because of this. Also, if you're sitting on your speaker you also can't hear how loud it is. 2. When playing in a band, re-eq your sound - mostly, cut the damn bass. A guitar tone that sounds great in the bedroom by yourself will likely sound like crap in a full band situation. The most common mistake is cranking up the low end to sound more "full". That's great, but it fights with the bass and kick drum and ends up making things like mud, leading to volume wars. 3. A low power tube amp cranked sounds infinitely better than a high power amp on 1. Guitars cut naturally - you don't need a ton of power to be heard. Oh, and wear ear protection when you play in a band situation. |
Modeling - hate it, hate it, hate it. They sound cool for the first 5 minutes, but then...
I gigged Studio 22 amps for many years. The last gigging amp I had was a Bogner Shiva. Seriously awesome amp with incredible touch sensitivity.
I have one of these on order. While bass is a different beast with different needs, those glowing bottles still provide some magic. http://www.juleamps.com/images/monique/monFRBIG.jpg |
I just feel disconnected from them somehow and prefer a simple quality tube circuit to let my guitar's voice sing through. Personal preference but Mesa, Fender, Orange and Marshall all work well for me. Soldano and Bogner certainly work well too but I don't take precious boutique amps to street fairs or clubs with drunks. ;) |
Man, that Mesa Boogie sounds awesome! Very clean sounding tone... Little out of my price range, but man, something to ponder...
Thanks for all the input guys... will be window shopping...
Line 6 makes some good "GASP" modeling amps as well.
You dont need a stack. ALso check out the Fender Hot Rod Deville |
+1 on the Deville. My next combo, if I ever get one.
