Registered ConfUser
Tire plug or patch?
Picked up a machine screw, about 1/4" in diameter in the center of a rear car tire (DD). Unscrewed it, reamed and inserted one of those 4" long black gewey plugs. Checked with soapy water and no sign of bubbles. Drove up and down freeway, came back and did it again....still no bubbles.
Any reason to have tire dismounted and patched? Are those plugs considered a permanent fix?
Thanks,
Mike
Old 01-22-2013, 12:22 PM
I plugged a bunch of tires at the service station in the '70's with good results, but would have to say the inside patch is better.
Jim
down to jap bikes that run and a dead Norton
Old 01-22-2013, 12:27 PM
Oh man...What now?
iplagolf's Avatar
I'm no tire guy but I have never plugged a tire. I believe it's best to patch it and re-balance. I always felt it disturbed (stretched) the area around the puncture.
Me and Porsche's go together like cocaine and waffles. Those don't go together. Well, peanut butter and women. Don't you mean jelly? You put jelly on women? (Ricky Bobby, Talladega Nights) 1985.5 944 Alpine white
Old 01-22-2013, 12:28 PM
MAGA
Tim Hancock's Avatar
I have probably installed 50-75 plugs in all sorts of tubeless tires over the years (ATV's, sports cars, trucks, mowers....). I do not recall EVER having one leak again from the same spot.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 01-22-2013, 12:36 PM
discount tire and just tires dismount the tire and plug patch it from the inside. for free.
so why not?
Old 01-22-2013, 01:19 PM
Registered ConfUser
so why not?
No Discount Tire for 80 miles.
Thanks for feedback. I suspect the plug will do the trick.
Old 01-22-2013, 02:17 PM
Friend of Warren
I'm with Tim. Never, ever had a plug go bad. Hell on the ATV I've shoved 2-3 plugs in a big hole and they have stayed in place. Probably plugged at least 10 street tires and the plugs have stayed right up until the tire is worn out and needed replacing.
Kurt V
Old 01-22-2013, 02:35 PM
dang that sucks!
if i remember correctly, cheap plugs causes fractures around the hole. but it's not like you're going to be hitting the track on plugged tires. so it'll prob be fine.
Old 01-22-2013, 02:37 PM
mikesride's Avatar
plugs are ok on all seasons, would never use them on a speed rated tire. Not an expert just my opinion.
I've driven alot of crap to get here man!
Old 01-22-2013, 02:38 PM
I've used plugs lots of times and only once had a problem with a plug that was leaking air through the rope fibers. I like them because I can do it myself.
But I think the best option is the plug-patch since it does both.
Tire Tech Information - Flat Tire Repairs
Old 01-22-2013, 03:48 PM
fastfredracing's Avatar
That plug will be fine.
No left turn un stoned
Old 01-22-2013, 03:53 PM
I've had tire people tell me to plug a radial and internally patch a regular tire. I've always done that with no problem.
Old 01-22-2013, 04:58 PM
Weseeeee911
I've plugged a bunch and so far no issues.
Al
80SC 95-present
Old 01-22-2013, 06:20 PM
Functionista
manbridge 74's Avatar
From the same school of thought that brought you $15 brake pads, witness the cheap black plug. Leaks through fibers and can come out under duress/higher pressures.
Spend a bit more and get the thicker orange ones if you want to worry less/have more success.
I like to add the cement stuff to the hole and plug. Just for the heck of it.
Plug patches are superior in every way but aren't as convenient.
Old 01-22-2013, 06:55 PM
pete3799's Avatar
Probably never have a problem with the external plug but if it was mine i would dismount and patch it on the inside.
I've been told that the fiber plugs can wick moisture in and rust the steel belts.
Pete
79 911SC RoW
Old 01-22-2013, 07:07 PM
Unregistered
sammyg2's Avatar
Given the choice I will go with a patch every time. I will only use a plug in an absolute emergency.
Old 01-23-2013, 05:44 AM
I have plugged tires many times with never a failure. Sure you can get into tire bands rusting, integrity of the tire violated, high speed issues. yadda yadda. This isn't a tire that is going on the Salt flats and running 500mph and I don't usally get more then 2-3 years out of a set. Any large operation garage will never do this because there is much more profit in selling you a tire (or pair since they don't like to sell unmatched sets) to charging $10 to plug it. If the tires have to come off for any reason, I would put a patch on the inside since that is optimal, but only if convenient.
Old 01-23-2013, 06:10 AM
A930Rocket's Avatar
Being in construction for years, I've plugged dozens of tires I've the years. Never a problem.
Old 01-23-2013, 06:15 AM
Slippery Slope Victim
NY65912's Avatar
Plenty of plugs. I plug as a temporary fix and then patch. Patch
Mike˛
1985 M491
Old 01-23-2013, 09:41 AM
Friend of Warren
Has anyone ever had a plug come out? Or even a friend of a friend's uncle? Not me.
Kurt V
Old 01-23-2013, 12:44 PM
