I see you
Steering problem with the Taco
2006 Tacoma 95,000 miles. The steering has become heavy rather suddenly (not overnight but I've only noticed it the past two days) it seems. It seems to be mostly when I turn right. It doesn't return to neutral after completing the turn.
Given that it's only on the right I don't think it's the pump or master cylinder. So maybe it's a thing with the rack? What do you guys think?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Parrothead member
yeah, sounds like a rack issue.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
I see you
I see you
2x or 4x?
Tire pressures good? Balljoint /tie rod end? CV boots good (if 4x)?
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Eva
Rack is shot. My Altima did same thing...gotta love warranty work
I see you
4X4...I hope the warranty covers it.
Edministrator
You have an extended warranty?
Good post? Leave a tip! O - $1 O - $2 O - $3 |
I see you
Edministrator
Should cover a steering rack, unless it's just a powertrain warranty. Check your coverage- and to make sure the warranty company is still in business... I seriously doubt Toyota would step up for something like this.
You do not have permissi
There's a TSB for pulling. Not sure of the cause. Several others for rattling: Service Bulletin 165331 for Toyota STEERING | AutoMD
2006 Toyota Tacoma Steering Service Bulletin 165331 "Repair manual supplement: vehicle pulling to one side. Toyota all model years. *mj 2002 - 2007 model years. Toyota/scion models." Besides the rack (more dangerous), it could be anything in the suspension. |
Sounds like your taco's rack is shot.
I see you
New rack
second set of new calipers no warranty 3K![]() ![]()
I see you
this has gotten ridiculous
Just found that the power steering lines need to be replaced too. WTF!!!
Tech says EVERYTHING IS COVERED WITH RUST. Fk me.
Rust you say. Hope your frame looks better than this.
2003 double cab.....was told by Toyota they wouldn't do anything for me because i didn't get my frame sprayed with their miracle juice. ![]()
A long flat piece of metal?
That's the easiest welding fix in the book, which only requires some thick plate....or lightweight I-beams with a cross of tubular to take it into 3D. |
Model Citizen
What the hell happened to Toyota quality in the past few years?
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Edministrator
What happened with the extended warranty? Did you take the truck to a dealer? If so, I'd get a second opinion at a reputable independent.
I see you
expired last year. and too late, the truck is in pieces
Last month i was hauling a used motor in the back of the taco to put into my daughters car when all of a sudden the back of the truck jumps into the air. I look back in the mirror and there's my spare tire laying in the middle of the road ![]() About a week later i get a notice for a recall on the spare tire carrier
