I see you
flatbutt's Avatar
Steering problem with the Taco
2006 Tacoma 95,000 miles. The steering has become heavy rather suddenly (not overnight but I've only noticed it the past two days) it seems. It seems to be mostly when I turn right. It doesn't return to neutral after completing the turn.
Given that it's only on the right I don't think it's the pump or master cylinder. So maybe it's a thing with the rack?
What do you guys think?
Old 03-16-2013, 05:16 PM
Parrothead member
VINMAN's Avatar
yeah, sounds like a rack issue.
Vinny
Old 03-16-2013, 05:18 PM
I see you
flatbutt's Avatar
Old 03-16-2013, 06:01 PM
I see you
flatbutt's Avatar
Old 03-16-2013, 07:04 PM
pete3799's Avatar
2x or 4x?
Tire pressures good?
Balljoint /tie rod end?
CV boots good (if 4x)?
Pete
79 911SC RoW
Old 03-16-2013, 07:37 PM
Eva
911SauCy's Avatar
Rack is shot. My Altima did same thing...gotta love warranty work
Old 03-16-2013, 07:43 PM
I see you
flatbutt's Avatar
4X4...I hope the warranty covers it.
Old 03-16-2013, 07:57 PM
Edministrator
Steve Carlton's Avatar
You have an extended warranty?
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 03-17-2013, 09:03 AM
I see you
flatbutt's Avatar
Hi ya Steve! yes I do.
Old 03-17-2013, 09:05 AM
Edministrator
Should cover a steering rack, unless it's just a powertrain warranty. Check your coverage- and to make sure the warranty company is still in business... I seriously doubt Toyota would step up for something like this.
O - $1
O - $2
O - $3
Old 03-17-2013, 09:45 AM
You do not have permissi
john70t's Avatar
There's a TSB for pulling. Not sure of the cause. Several others for rattling: Service Bulletin 165331 for Toyota STEERING | AutoMD
2006 Toyota Tacoma Steering Service Bulletin 165331
"Repair manual supplement: vehicle pulling to one side. Toyota all model years. *mj 2002 - 2007 model years. Toyota/scion models."
Besides the rack (more dangerous), it could be anything in the suspension.
Old 03-17-2013, 01:02 PM
wdfifteen's Avatar
Sounds like your taco's rack is shot.
Old 03-17-2013, 01:16 PM
I see you
flatbutt's Avatar
New rack second set of new calipers no warranty 3K
Old 03-27-2013, 08:50 AM
I see you
flatbutt's Avatar
this has gotten ridiculous
Just found that the power steering lines need to be replaced too. WTF!!!
Tech says EVERYTHING IS COVERED WITH RUST. Fk me.
Old 03-29-2013, 10:21 AM
pete3799's Avatar
Rust you say. Hope your frame looks better than this.
2003 double cab.....was told by Toyota they wouldn't do anything for me because i didn't get my frame sprayed with their miracle juice.
Pete
79 911SC RoW
Old 03-29-2013, 11:24 AM
john70t's Avatar
A long flat piece of metal?
That's the easiest welding fix in the book, which only requires some thick plate....or lightweight I-beams with a cross of tubular to take it into 3D.
Old 03-29-2013, 12:21 PM
Model Citizen
herr_oberst's Avatar
What the hell happened to Toyota quality in the past few years?
Old 03-29-2013, 01:59 PM
Edministrator
What happened with the extended warranty? Did you take the truck to a dealer? If so, I'd get a second opinion at a reputable independent.
O - $1
O - $2
O - $3
Old 03-29-2013, 06:52 PM
I see you
flatbutt's Avatar
expired last year. and too late, the truck is in pieces
Old 03-29-2013, 07:30 PM
pete3799's Avatar
I plated both sides (other side was cracked too) and a new cross member.
Last month i was hauling a used motor in the back of the taco to put into my daughters car when all of a sudden the back of the truck jumps into the air.
I look back in the mirror and there's my spare tire laying in the middle of the road
About a week later i get a notice for a recall on the spare tire carrier
Pete
79 911SC RoW
Old 03-29-2013, 08:58 PM
