-   -   Help for an electrical feebe..... (http://forums.pelicanparts.com/showthread.php?t=759445)
Cajundaddy 07-07-2013 08:52 AM
Nicely done! I have re-soldered and repaired amplifiers with similar results because I was too cheap to spring for a new board. Intermittent problems are often the most difficult to diagnose but the easiest to repair. Nearly always a loose wire/loose connection.
spuggy 07-07-2013 09:53 AM
Originally Posted by Bob Kontak (Post 7534978)
TI just used the solder the electronics store suggested I buy. Don't believe it is cored. Came in a plastic tube that is long gone.
It's almost certainly multi-cored solder if you bought it from an electronics store, 'coz only plumbers/metalworkers use "real" solder with separate flux - and there would just no point for electronics work, unless you were soldering honking great heat sinks...
Does give a little puff of smoke when you tin the iron with it? If "yes", there you go; that's flux burning off; solder doesn't smoke when it melts :)
Solder on that board looks a little light/scanty - but pretty good compared to most of the 80's bosch electronics I've seen - amazed most of that stuff ever worked, much less worked for 25 years before it stopped working and needed to be re-flowed...
