Family Values
Invest a few dollars in one of those USB drive adapters. It has IDE and SATA interface plugs on it, so you can access the HD from another PC that boots up.
- Joe Necessity is the plea for every infringement of human freedom. It is the argument of tyrants; it is the creed of slaves. - William Pitt |
canna change law physics
The SATA interface on the DRIVE was dead. It also happened to have a USB interface which was intermittent...
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Family Values
Right, but you're not relying on the failing drive for boot up any more. You're using it for storage, which would allow you to wiggle/jiggle the connector more easily and possibly would have saved you a ton of time.
I'm not using it for storage.
It is a dead drive. It is no more. It is an "ex" drive. Anyway, the issue is not using a SATA to USB interface, the SATA interface on the drive is dead. It is a special drive in that it also has a mini-USB connector on the drive. So, there wasn't even a need for the USB to SATA interface. The wiggling wasn't on the cable, it was pressing the chips and components on the drive to reconnect whatever was intermittent. See, I have the drive pulled apart. On an SSD, this means the cover is off and the PCB is exposed/removed.
The Unsettler
Not that he was advocating trying to use the drive going forward. FWIW I have two myself. Indispensable when you jack around with as much stuff as we tend to. I've got the block and cable kind for portability and the dock kind that sits on my desk.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
I have 2 of those. And the SSD drive actually has a USB connector, so it isn't needed.
And it makes no difference, since those USB to SATA interfaces use the SATA interface, which is dead on the drive.
"Replacing with a standard 2.5" drive. "
We thank you for your business!
'78 Targa Sold! '84 Carrera Sold! '01 996 Wrecked |
