Super Moderator
It IS a temperature thing though. ...but not temperature of the engine, temperature of the output!
So why not use a temperature switch on the output of the AC itself. It the AC is running and the output is above, say 55 degrees, then turn the fan on?
I am one of the folks that only rolls down my window to talk to someone like a toll booth attendant or something like that. I don't ever ride around with the window open even on a perfect day. I have too many allergies. I drove an un air conditioned 914 for over 20 years. I have had a lifetime of open air driving. BTDT. I an't gong back. Either my heater is on or the AC is on. A pressure switch might work if I could calibrate it to the high pressures, but that is going to be a challenge to graft into the system. The brake pedal seems to be the best suggestion so far.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Just thinking out loud
It's all about the delta T from condenser input and output, not the evaporator or vent temps, although 40 degrees at 100 ambient is a bit high for my liking. Should be down in the 20's
83 944 91 FJ80 84 Ram Charger (now gone) |
The 40 degree temp is the air temp with the fan on MAX blow. If I lower the fan speed it gets Down to 32 degrees air temp from the center vents.
Drop the pressures a tad so where it nearly ices up the evaporator. LOL.
Naw, it's cold enough. Did you integrate a cabin air filter to rid yourself of outside pollens?
83 944 91 FJ80 84 Ram Charger (now gone) Last edited by mattdavis11; 08-23-2013 at 12:32 PM.. |
canna change law physics
Flow switch.
Air Flow Switch for DC/ AC Voltage Supplies (Type 3201.-/3204.-) These are factory set to 3m/s or about 10 feet per second. You will need to duct some air or place it in an area sure to sense flow.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Now he has to go with a 24v DC supply. I like where this is going.
Actually, if he is willing to DIY, he could build his own flow switch.
Use a piece hard metal dryer duct with a flapper at the end. Put a switch in the duct so that the flap activates it when there is no airflow. You will probably need to add a weight to the flap to get it to activate the switch. I would put a relay inline, since these types of switches are not really well suited for lots of current.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 Last edited by red-beard; 08-23-2013 at 01:15 PM.. |
Now we're jumping the shark! Bout time!
James I like it! I would have NEVER thought of that.
Now I gotta figure out how big that is and where to mount it. It will have to be hidden fairly well. I love the out of the box thinking. It would be something to talk about when I show my boring stock 350 engine. As Spock might say Fascinating. I will look into that as well as the speed sensor idea. I was thinking about the speed sensor idea. I know that I can hook my laptop up to the ALDL and monitor output from the fuel injection computer. It shows the speed, and throttle position and O2 sensor readings. It also know what gear the transmission is in and other values. Nothing can be changed from the fixed program, but you can see what is going on. I really need a motor-head 18 year old programming geek to figure out how to integrate all the readings just to turn a fan on and off.
Where did you find the metal vent? I need one of those for the house. Or crazy dog decided the plastic driver vents are tasty and destroys one about every two months.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! Last edited by GH85Carrera; 08-23-2013 at 03:16 PM.. |
5 prong relay. Compressor closes one portion, then the brakes close the loop, energizing the relay to turn the fan on.
83 944 91 FJ80 84 Ram Charger (now gone) Last edited by mattdavis11; 08-23-2013 at 03:49 PM.. |
Hell Belcho
Just go off the TPS.
Saved by the buoyancy of citrus. |
That is very logical. I just need to figure out how do do that.
You do not have permissi
We're going to need a bigger ramp:
Going to then have to figure out how to get more output to make that relay work. TPS range on a TBI motor is said to be .5v to 5v DC at WOT.
83 944 91 FJ80 84 Ram Charger (now gone) Last edited by mattdavis11; 08-24-2013 at 06:15 AM.. |
Hmm...my Audi has a visco clutch fan + electric fan that only kicks in when gas pressure is too high = cooling flow is bad. Can't you use something similar?
Thank you for your time, |
I don't think cheese meant to use the TPS voltage, just the movement to activate a switch. Problem with this is having the fan run on cool days and cold nights at idle.
RB's idea sounds pretty good except for the same problem. Same with the GPS. The solution can't have anything to do with speed, motion or air flow, IMHO. The orifice sounds interesting, but even with the explanation I don't completely understand if it will do what Glen needs to do, activate a fan in hot conditions when stopped. The in-duct temp sensor might be tardy in operating the fan and shutting it down. He could be doing 40 before the duct temps fell. That's why he asked here because if it were easy, he'd have done it already. I guess I'd install a horn button within reach and use the horn ring to run the fan. Not going to help the valet.
Straight shooter
I would not touch any reference voltages with the ecu. I like the brake light switch recommendation as it's 12v and not ecu/tune impacting at all. Just put the relay in series with the clutch feed so only when ac is running. Cost is near nil.
You could also use a shift light with programmable 12v output to kick a relay as well.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 08-24-2013 at 06:15 PM.. |
