Registered Usurper
Worth reading...Ha!
If you start with a cage containing five monkeys and inside the cage,
hang a banana on a string from the top and then you place a set of stairs under the banana, before long a monkey will go to the stairs and climb toward the banana. As soon as he touches the stairs, you spray all the other monkeys with cold water. After a while another monkey makes an attempt with same result... all the other monkeys are sprayed with cold water. Pretty soon when another monkey tries to climb the stairs, the other monkeys will try to prevent it. Now, put the cold water away. Remove one monkey from the cage and replace it with a new one. The new monkey sees the banana and attempts to climb the stairs. To his shock, all of the other monkeys beat the crap out of him. After another attempt and attack, he knows that if he tries to climb the stairs he will be assaulted. Next, remove another of the original five monkeys, replacing it with a new one.*The newcomer goes to the stairs and is attacked. The previous newcomer takes part in the punishment...... with enthusiasm, because he is now part of the "team". Then, replace a third original monkey with a new one, followed by the fourth, then the fifth. Every time the newest monkey takes to the stairs, he is attacked. Now, the monkeys that are beating him up have no idea why they were not permitted to climb the stairs. Neither do they know why they are participating in the beating of the newest monkey. Finally, having replaced all of the original monkeys, none of the remaining monkeys will have ever been sprayed with cold water. Nevertheless, not one of the monkeys will try to climb the stairway for the banana. Why, you ask? Because in their minds...that is the way it has always been! This, my friends, is how Congress operates... and this is why, from time to time: ALL of the monkeys need to be REPLACED AT THE SAME TIME.
'82 SC RoW coupe |
Bill is Dead.
Comparing monkeys to Congress is insulting to the monkeys.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
I agree.
Glen 50 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
That's the premise of the classic short story, "The Lottery".
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
