Replacing outside breaker
The breaker on the outside of my building is tripping when my silk screen dryer and flash dryer are on. Never used to.
Anyone ever change the breaker on a main box? Do I have the e- company turn off power to it? ![]() ![]()
Tru6 Restoration & Design |
i don't think they are a big deal to replace, but someone with more knowledge can confirm. i think just make sure that everything they feed is off and replace. But don't take my word for it, wait for an expert.
Is there a main breaker upline from that 3 pole 100 amp?
--------------------------------------------------------------------------- "Prayer isn't a parachute. It's a compass. It doesn't save you from the storm. It guides you through it." - Bear Grylls |
Craig, I think this is the main breaker. Wires go from the pole to a huge steel conduit at the top of the building, that runs down to the box and meter.
If that's the one that's tripping I'd call a professional, that's a lot of juice to get hit with!
Detached Member
I'd have the e-company pull the meter, you may just need to take a stiff wire brush to the buss bars.
Hugh Last edited by Hugh R; 01-19-2014 at 11:39 AM.. |
Thanks. E-company will only turn off juice. I don't think they will do it if I call and tell them too. Will call tomorrow and see.
Detached Member
E-company turns off juice, its dead, you take wire brush to the buss bars, and inspect/replace the breakers. Price out those breakers first, they could be no longer available. They look old and breakers, especially, old ones ,are known to fail just from taking them out and futzing with them.
100 amp!! That will kill you if you don't know what you're doing. Please hire a professional.
IMO the breakers get old and trigger all the time when the load is close to limit.
We're all in the gutter,but some of us are looking at the stars. -Oscar Wilde |
Great information, thanks. I'm hoping the E-company will turn off the e- with only my call.
this one looks similar Siemens Q3100 100-Amp 3 Pole 240-Volt 10-Kaic Circuit Breaker - Amazon.com
My house is 100 amp, its no big deal to add a new breaker with power on. They clip in and out, about as dangerous as flicking a light switch.
BUT......the breaker may just be doing its job!!!! It is important to call someone in to insure that you do not have an electrical issue down the line that is causing the breaker to pop. This happened everytime I turned on the toaster at home.... Then the toaster tried to electrocute me!!!! The issue was the worn out toaster not the breaker.
I've driven alot of crap to get here man! |
OK, Mike, I'm taking you out of my will.
call an electrician, will your insurance company cover you if you do it incorrectly?
Chris the more i learn, the less i know |
Parrothead member
Shaun, being an electrician, the best advice I can give you is to have an electrician look at it. The breaker is tripping for a reason.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Last time I screwed with the main breakers I wound up replacing the service panel and it took a day. Twas shot.
Are your dryers 3 phase? I am just curious how they balance the loads.
Rick 88 Cab |
Monkey+Football
What Vin said. Replacing a breaker, even a 3 pole is easy. Done it many times. You need to now WHY it's tripping. Better to have a pro verify the load. Be safe.
<Insert witty comment> 85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff. |
The main dryer is 3-phase, the stand alone unit is just 110 in the wall on a 30A circuit.
I'm going to take the box cover off tomorrow and see what's in there. Can't hurt.
Shuan,
I don't think its the Breakers, but I have been known to be dead wrong. It might be something else that's tripping it. Cheap enough to change out the breakers and see if its still doing it. Hire someone to change out the breakers because it should be cheap enough to do if you feel uncomfortable doing it yourself. Its a 5 minute job. |
