-   -   Air compressor recommendations (http://forums.pelicanparts.com/showthread.php?t=802058)
drleah 03-20-2014 06:27 AM
Hubby wants to replace the aging upright compressor in the garage with a 60 gallon 220v one. Anybody have one they love (or hate)?
Thanks,
Leah
pete3799 03-20-2014 07:01 AM
I bought one of these 3 years ago...........only use it occasionally .....does everything I need.
No problems with it so far.
Campbell Hausfeld® 60 Gallon Cast Iron Air Compressor - Tractor Supply Co.
MBAtarga 03-20-2014 07:11 AM
That "aging upright" compressor may be better quality than 99% of compressors being sold to the average consumer these days.
Is it actually malfunctioning?
asphaltgambler 03-20-2014 07:39 AM
Originally Posted by mbatarga (Post 7971192)
that "aging upright" compressor may be better quality than 99% of compressors being sold to the average consumer these days.
^^^^^^^^^^^++1111^^^^^^^^^^
Porchdog 03-20-2014 07:48 AM
So long as the bottom of the tank isn't rusting and the compressor he has is large enough -
Rebuild (or pay someone to rebuild) the compressor head. Renew the control parts. Install an automatic drain.
In the future - be sure it's draining. Change the oil regularly.
Then you have plenty of money left over for other toys.
If your current unit is to small or has a rusty tank - I'm interested in the answers as well. My current compressor is to small. Every "classic" compressor I've tried to buy has had a rotten tank.
I do have 3 great compressor heads (2 rebuilt), but no tanks to use them with.
drleah 03-20-2014 10:56 AM
Compressor isn't large enough, 1.5hp. Impact driver after 2 lug nuts causes it to cycle for 20 minutes minimum.
Thanks for the recommendation Pete. That is one of the ones he's looking at.
MBAtarga 03-20-2014 11:11 AM
Just stick with the oil cooled pumps - more popular brands and you'll be fine.
I've got the IR equivalent of the CH brand in the link.
june82000 03-20-2014 12:27 PM
I bought the 60 gallon compressor at Home Depot back in 2004 or 2005. I think I paid 450 for it using a 10% of coupon. It's been a great compressor - I love it!
rfuerst911sc 03-20-2014 03:53 PM
Ingersol Rand they are excellent quality and will run forever in a DIY garage. I have a 60 gallon twin cylinder she is a workhorse. Parts are available and to my knowledge built in the U.S. I stole mine off Craigslist from a company going out of business.
pavulon 03-20-2014 04:11 PM
has anyone ever been around a compressor tank that failed and had the failure attributed to age? Details?
drleah 03-20-2014 06:45 PM
Thanks for all the info guys!
dmcummins 03-21-2014 06:14 AM
To bad your not closer. I'm getting ready to move and have a 220V industrial compressor that I'm not moving across country. It was originally 3phase and I changed the motor to 220V. But its heavy and way more than I need these days. I use to paint a car now and then, now I just air up tires.
Nickshu 03-21-2014 06:30 AM
I have a Husky/Home Depot 60gal. I wish I had an 80-90gal. Using my bead blaster I think it has to run more than it should to keep up.
ky911sc 03-21-2014 01:15 PM
In a past job I worked for a compressor company as QC manager.
I saw several pressure vessels that failed/ruptured. If the tank has pin hole leaks, do not repair it. It will be thin in multiple areas, and if you weld/patch the tank, it will fail dramatically near the welded areas. Most tanks are never coated inside, the black scale of the steel does protect for a while but the water will eventually rust out the tank. Drain your tanks every time you use them and they will last for years.
drleah 03-21-2014 07:09 PM
dmcummins, wish you were closer and we would definitely be talking! kysc911sc, that is what he does now. But really good to know, thanks!
Brtuffli 03-21-2014 07:44 PM
I'm in St. Louis and interested in your compressor. Price? Age? Etc
Brock
