Can you identify this Audi A4 part?
Heard a wooshing sound from my A4 instead of a whine from the turbo. Checked under the hood and found that this part had separated from its housing causing a serious air leak. New to turbos so I don't know what to search for. Thanks
Fleabit peanut monkey
That is an issue. Boost leak vs air leak? Diverter valve area? Take a pic a foot back.
Assuming the whooshing sound is heard when you should be getting boost. 2002 Turbo Beetle/2003 Passat 1.8L Turbo. Will never have another. But I digress.
1981 911SC Targa Last edited by Bob Kontak; 11-15-2015 at 04:53 PM.. |
Hell Belcho
Ah, VW plastics.
Saved by the buoyancy of citrus. |
Is that the top of the radiator? Yes, give us a little more context. It looks liek you may have to replace the y pipe and the tube that goes into it. Is there a slight crack at y point?
And regarding VW plastics, I am sorry, but I have to agree. I had 2 A4s 1998 and 2004, LOVED them. However, after 150k miles all the plastics start to dryrot and fail. I replaced about a dozen plastic peices on my car. None were extremely expensive but VERY time consuming to replace. I am hoping my new volvo will get me past 200k... We shall see 180k to go!
1976 911S; 1957 Mercedes 190SL; 1982 Ferrari Mondial Coupe; 1991 Nissan Figaro; 2001 Panoz Esperante ; 1969 Pitts S1C http://forums.pelicanparts.com/porsche-911-technical-forum/664950-1976-911s-garage-find-road.html |
It is some sort of one way check valve doohickey part of the pcv system
No left turn un stoned |
Venturi tube?
dolor et pavor Copyright |
You do not have permissi
The top piece looks like a traditional PCV (positive crankcase ventilation) check-valve to me.
-It recirculates blowby and oil vapors in the case back into the intake to be burned up. -It keeps the engine gaskets from pushing out when the rings are failing. When the leaking compression/ignition charge wants to pressure up the aluminum case just like a balloon. Does that thing lead to the brake booster? Or to a canister such as with an EVAP system?
Meanwhile other things are still happening. |
Still Doin Time
^^^Winner! ^^^^ that is mostly correct -re-circulation...... valve - they fail early and often. Usually associated with CE on.........
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Thanks for the feedback, guys. Discovered it is the suction jet pump, which apparently can affect the brakes! A new one is on the way from our host. It's a 2002 A4, so I plan to replace all the check valves soon too.
