Information Junky
I'm just keeping with the designer's theme here.
![]() Next up, cross-drilled brake lines!
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
abides.
Why not just replicate the dents that are used in the factory euro crush tubes?
Graham 1984 Carrera Targa |
My friend Chris just drafted this up. I like it but would be a manufacturing nightmare I think.
Tru6 Restoration & Design |
You do not have permissi
I was thinking about post #2 and the near total failure of a steering column.
Aluminum doesn't give warning and it's either there or it isn't. Yeah it's a hack but wire is light. I imagined Shawn getting a good tap in the parking lot, then driving home in heavy traffic at speed. The flex part has been broken 95%. He rolls over a pothole and the front bumper falls off and rolls under the car. Not good.
Meanwhile other things are still happening. |
Information Junky
Yeah, Aluminum doesn't have the toughness of steel.
where's my popcorn? oh..
Lots of snow Porsche away
what if you were to use the Al tubes to sleeve a (obviously as light as possible) steel spring to assist with the damping force? The inserted spring would both dampen the collision force and prevent the buckling from collapsing the Al tube inwards, forcing it to buckle outwards which may assist in keeping the forces in line...
I understood that the damping force in the front bumper shocks was largely due to them being fluid filled, and the metered release of the damping fluid after collision provided the damping much more than the buckle zones on the shocks. I know due to a rear end collision that I suffered in my 76 911S that this is how the rear shocks are intended to work, in my case they were not fluid filled (leaked out over time I am told) and thus the full force was transmitted to my tub after the shock tube distorted to its limit.
76 911S 86 GMC K1500 78 XS750 cafe racer to be 79 XS750 because one is just not enough |
This would be much easier to fab, and the honeycomb has a huge energy absorption to weight ratio
84 930 18 Cayman GTS |
abides.
Ok, I'm out.
Thanks Aschen, can you describe/show the honeycomb and its orientation?
Why not fill the fiberglass bumper with expanding foam to absorb impact?
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
I'm keeping the Al bumpers, just making them lighter.
![]() ![]() Goofing around with FEA with a model of a 2" OD x .125" wall 6061-T6 aluminum tube with 50,000 lb slightly offset force gives this result. It doesn't really show you how it would collapse though. I'd mock up a piece, bolt it to a tree or something else that won't give and bump into with a beater truck
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
least common denominator
I had the same thought...
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Platinum Member
![]() 3 sections of Mcmaster-Carr square 1/8 wall 1"x4" aluminum tubing, part number 88875K21, cut to the height you want (2" shown) bolted side to side to get 12" total length. Easy to machine, drill press and a chop saw...... For proper crash testing you will need to provide me with 12 running cars.... David, you using solidworks? Last edited by dad911; 07-22-2015 at 02:33 PM.. |
McMaster-Carr If you choose a 1" thick material, maybe you need 2-3 pieces in series. They have the loads listed so you could pick an appropriate cell density. For example if you want the material to crumple at 500 Lbs force you might pic 4 square inches of 250 psi rated material I would orient the material such that the long axis of the cells are parellel to the direction of travel. You are relying on the cells buckling but they are thinwall so they will give in near rated load. The should crumple and absorb work.
Thanks Aschen, that is very interesting. I wonder if the 8458K66 would be best. the bracket sizes are different about about 2.5x3.5 inches.
Thank you David, and I happen to have a beater truck.
![]() I see some testing in my future. Probably should have ordered a lot more tube. I'm also going to try the horizontal cuts staggered around the tube. It would be much easier to produce these. Quote:
