What causes this blue build up on my battery posts? Oxidation? I've cleaned them in the past and lubed with dielectric grease but it returns.
Henri Owned for 21 years: '87 Carrera coupe Venetian blue |
Control Group
I believe that is copper sulfate. The copper in the cable reacts with the sulfuric acid in the battery.
She was the kindest person I ever met |
The top of your battery looks nasty. You must have a leak or excess charging and bubbling of gasses and acid.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Do you clean the clamps also?
Paul 82 911SC - 3 yrs of fun (traded-in) 2011 Cayman (simply amazing, smiles for miles) |
From Wikipedia
"Sometimes, it also happens that copper clamps or ringed copper terminals which are used to connect battery with wires corrode. Copper itself is not reactive even if dilute sulphuric acid is poured on it. But when electricity passes, it reacts with sulphuric acid and produce copper sulphate ( CuSO4 ) along with water and sulphur dioxide gas. The equation of this chemical reaction is following: Cu (s) + 2 H2SO4 (ℓ) → CuSO4 (aq) + 2 H2O (ℓ) + SO2 (g)"
gary |
Mix Baking powder and water to clean that up then thin coat the ends with a grease (i use bearing grease)
Rick 93 968 (My summer car), 05 Cayenne S (My winter car), 79 924 (Wife's summer car), 02 C230k (Wife's winter car), |
Edministrator
Oh, pretty!
Good post? Leave a tip! O - $1 O - $2 O - $3 |
I'd also recommend getting some of the felt washers that PEP Boys sells and put them under the clamps. I think you usually soak them in ATF to help form a barrier to the fumes.
I'd pull the caps off and see if you have some low electrolyte levels in the cells.
Scott '78 SC mit Sportomatic - Sold |
Baking soda.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Put them on the posts, tight to the case. They work well. Check your battery and voltmeter; you may be overcharging. Looks like a sealed battery. How old is it? Last edited by tcar; 02-09-2016 at 10:04 AM.. |
Make Bruins Great Again
just don't let the baking soda get down into the cells.
I think I read somewhere that cola will clean that crud off as well but then you have to clean the cola....
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Model Citizen
Chia posts!
Senior Advisor
so your battery is making more little batteries? anyway, WD40 will also keep them clean, after you clean them up once every 10 years or so.
08 Cayenne Turbo |
It's my Honda DD appliance. It's only rhe second battery since '02. I put it in Dec '09. Have not checked levels, but will do so now. I thought the dielectric grease would keep that copper sulphate at bay. I'll clean again and might try the felt below the clamps. I'll try the baking soda for cleaning this time. Battery is likely nearing end of life.
Thanks for the replies.
Henri - You'll probably find the clamps are toast under the blue stuff. Don't ask how I know. I'd say get a new battery since you're going to be cleaning the cable ends. It'll save you time since the battery is probably compromised already if it's from '09.
My '02 Accord went thru 2 batteries in 9 yrs of its 153k mile life while I had it.
I have found that the felt pads with NO grease works best.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Hot water will work as well. New conventional batteries come with a sealed top (you can still open them and add water) but have a vent tube that collects any gasses and it goes down below the battery to vent. Just replaced the battery for my 08 Chevy pickup and the new battery came with the vent tube.
Bunch of old cars
I have seen old timer mechanics place a penny between the connector, and post. I have also seen them use grease instead of dielectric. Should prolly clean them. The resistance is super high and will cause a no start.
dolor et pavor Copyright |
why?
i think the alt is charging on the high side. put a V-meter on it and check it out.
poof! gone |
