-   -   Two Cylinder Engine Question (http://forums.pelicanparts.com/showthread.php?t=908912)
1990C4S 04-04-2016 01:16 PM
I was 'given' a two cylinder engine for a small home project, but it has no starter.
First issue is to figure out which way it should rotate.
I would think the easiest way is to look at the valves while I crank it manually, and make sure it sucks through the intake (and intake valves) and exhausts out the muffler (and the exhaust valves)?
Yes?
Arizona_928 04-04-2016 02:14 PM
50:50 shot. Just try to run it? My money is on clockwise...
1990C4S 04-04-2016 02:27 PM
Clockwise rotation when facing the engine (i.e. output shaft at rear) is normal I think...
So standing at the front of your RWD car engine's typically rotate CW. I think.
Arizona_928 04-04-2016 02:28 PM
you're right ^^
The only ccw rotation I can think of would be marine for dual engines....
yetibone 04-04-2016 04:05 PM
Originally Posted by AZ_porschekid (Post 9066093)
you're right ^^
Corvairs, some older Honda, and Mitsubishi 4 cylinders also turn CCW.
wdfifteen 04-04-2016 06:00 PM
I would start by identifying the make and model. With that info you can probably find a manual on line that would provide all kinds of useful information.
Arizona_928 04-04-2016 07:39 PM
dang it... you caught me... I was thinking Corvairs after I wrote that. I don't think I have personally ran into any besides marine, and Crovairs.
bell 04-05-2016 04:57 AM
Turn it by hand and check for suction on the intake
1990C4S 04-05-2016 05:00 AM
Thanks guys. I think I have this now...
