abit off center
cgarr's Avatar
We just got our new miller 252? or something like that in our shop, Im new to mig, its been all tig and gas welding for me til now: I was having popping problems, watched the vid, set it all up and still had the problem, ended up being the tension on the wire feed, it looked fine but when you go to weld the slight pressure of the wire going into the work paused, or slipped a bit so the wire was stopping and starting, increased the tension and works perfect!
______________________
Craig
G2Performance
Old 05-01-2016, 09:13 AM
What voltage and wire feed speed are you running? What size wire?
Old 05-01-2016, 10:54 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
Popping is usually caused by low heat. What is your setting on now?
Old 05-01-2016, 08:24 PM
Low heat also causes bad weld penetration. I like to start at higher heat and adjust wire speed till you get the frying bacon sound and stack of dimes flat welds.
Old 05-01-2016, 09:28 PM
rnln's Avatar
I still have not tried it after the last response. My Lincohn 100 has 3 settings for heat: B, C, and D I think. And wire speed from 1 to 10 (or 9). I tried all heat settings. On wire speed, I tried between 4 to 7. On welding thin metal, maybe 1/16", I felt that the wire was moving faster than my hands. I usually use flux wire 0.035.
When I pull the trigger without welding (without touching the metal), I see/feel that the wire coming smooth.
Sometimes I got good bacon frying sound and laying dimes nicely, but rare.
Fat butt 911, 1987
Old 05-04-2016, 03:07 AM
Make sure the wire can feed smoothly directly from the gun without welding. That's step one.
And make sure your tip is not worn out.
Old 05-04-2016, 05:07 AM
T77911S's Avatar
polarity is reversed if using flux core vs wire with gas.
not an expert at welding by any means but even rusty or dirty metal wont cause it to pop, I have tested welding rusty crap like rebar.
someone said it earlier. too much heat with too slow a wire feed.
here is what I have done when I first started.
while welding, take your other hand and adjust the wire feed up and down. listen to how it sounds when the wire feed is too fast and too slow.
listen for when it sounds like bacon cooking.
change the heat setting and then repeat and notice how the weld changes.
I practiced a lot with flux core just because it was cheaper.
if the polarity is reversed you will get a lot of little balls that will stick to the metal that are a pain to remove.
it seemed like the flux core welded cheap soft metal better.
I also spent a lot of time trying to weld thin metal. I figured that was harder than thicker.
my welder will also do stick welding. my stick welding is worse than my mig so I work on that more.
I cant believe I went as long as I did with out a welder.
Saturday I welded an allen wrench to the small screw that holds a brake rotor on.
then welded a bar to large nut that holds the shock inside a front strut.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-04-2016, 05:20 AM
rnln's Avatar
Does anyone know if I can weld iron to aluminum?
Fat butt 911, 1987
Old 05-11-2016, 01:28 AM
Staubsauger!'s Avatar
Hahahhhah du bist blöde...
Die Kirche im Dorf lassen
Old 05-11-2016, 01:57 AM
Crazy glue.
Old 05-11-2016, 05:07 AM
You do not have permissi
john70t's Avatar
Not possible.
Aluminum is very tough to weld. Because it conducts heat so well it just burns through in a giant blob. There is no color change or indication of when it is hot and about to melt. It just suddenly melts and usually burns through.
For a MIG setup:
Aluminum wire is too soft for any welder to push through a line.
You need a special powered spool gun at the end and different gas.
Even then results will be very substandard without a ton of experience.
Practice make perfect, so get a bunch of scrap and practice.
Old 05-11-2016, 06:01 AM
abit off center
cgarr's Avatar
I love our spool gun, getting better at it
Sent from me
Craig
G2Performance
Old 05-11-2016, 06:24 AM
rnln's Avatar
will try. thanks
Originally Posted by 1990C4S View Post
Crazy glue.
Fat butt 911, 1987
Old 05-15-2016, 01:44 AM
rnln's Avatar
Thanks John,
I know it's impossible when seeing 1990C4S response.
Not possible.
For a MIG setup:
Fat butt 911, 1987
Old 05-15-2016, 01:47 AM
rnln's Avatar
I tried this again today, after cleaning up everything, include ground cable and clamp. This is a great method to find the hot spot, thanks.
I used to adjust the wire feed knob with 1 increasement, then weld then increase again then weld. This was hard to find the hot spot. And I used to hold the gun with both hands tight, to the point my hands get tired. Today, I can relax holding it with one hand and adjust the wire feed with the other hand. I could easily find a good spot, but still feel that it is not good enough. I was welding a clean rebar to a clean galvanized pole. I tried both of the higher temp settings. At the spot where it sounded like frying bacon, then I feel wire comes out too slow (weld mark looks too thin. It's called cold weld?). If I increase the wire speed just a little, then it start popping a little, then I back down. Maybe that is the best my Lincoln 100 can do?
Fat butt 911, 1987
Old 05-15-2016, 02:02 AM
I suspect your machine is the limitation.
I am a decent welder. I can rarely make a good weld with the basic 'garage welders'.
Hold the gun in mid-air and pull the trigger. Try to stop the wire from feeding by squeezing it between your fingers. If it is feeding well it will be very hard to stall the wire feeder. If it stall easily your wire feed is part of your problem.
Old 05-15-2016, 09:56 AM
coulda, woulda, shoulda
johnco's Avatar
"I was welding a clean rebar to a clean galvanized pole"
you're never going to get a clean weld with no popping welding on galv. I was a welder for many years and welded on lots of galv. grating. inhale a bunch of the galv. smoke and the fun starts later that night when you start puking your guts out
John
74 911s
Old 05-15-2016, 10:42 AM
abit off center
cgarr's Avatar
This is the problem I had, the wire fed out fine until it hit the work, fought that problem for awhile until I if figured to increase the tension on the feed, what a difference when its setup right.
And please don't breath the green gas when doing galvanized metal, put me out of commission for a week!
Craig
G2Performance
Old 05-15-2016, 12:42 PM
Fleabit peanut monkey
Bob Kontak's Avatar
This is great info. There is a dial inside the box to increase the tension on this new MIG 180 Lincoln I have. Can you go too far the other way? Too much tension?
I am such a noob.
1981 911SC Targa
Old 05-15-2016, 02:26 PM
johnco's Avatar
if you tighten the tension too much and happen to short the tip and block/weld the wire in it, you have a nice bird's nest of wire inside the machine past the tensioner/drive wheel
John
74 911s
Old 05-15-2016, 03:06 PM
