Here: includes the unloader....
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
wdfifteen, I can't find their website.
1990C4S, Is this the same as the one I posted above? Do you know which part is the unloader? Are the 2 brass fitting (with the little holes) are the check valve (the part that is broken on my air compressor)? Thanks guys.
Fat butt 911, 1987 |
UnRegistered User
I think that the unloader is built into the pressure switch on the bottom.
It appears that the compressor discharge enters into the bottom of the pressure switch and that the pressure to the tank goes unregulated into the tank. Pressure to the lines passes through the regulator to the hose couplings. Something that doesn't make sense to me is that the relief valve appears to be on the regulated air side of the manifold.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. Last edited by billybek; 04-05-2017 at 04:38 AM.. |
I got down and took everything apart to hold it on my hands and took some pics. The metal ball that popped out from the bottom of the port which connect the air hose to has nothing as a valve. At the elbow, there is hole which the ball fit tight in there. I think it's for safety as an emergency release valve, in case of over pressured, the ball pops and releases air. Why it popped while the pressured wasn't over? I think because it is too old. I pressed it back in the hole and installed everything back for right now. Let see how it goes. If I can find a better manifolds set, I would replace it.
The valve at the top where I labeled "Check valve?" has a ball and a spring inside to stop air to backward. It should be a check valve? Question, what does the unloader do? ![]() ![]()
Fat butt 911, 1987 Last edited by rnln; 04-06-2017 at 12:15 AM.. |
UnRegistered User
The unloader releases the pressure in the cylinder and discharge line after shutdown. This allows for an "unloaded" start. Compressor starts easier without pressure on the discharge side to overcome while starting.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Platinum Member
Hate to say it, but how old is the tank/compressor? and chance of rust in/on tank? maybe it's time for a new one.....
The truth is that while those on the left - particularly the far left - claim to be tolerant and welcoming of diversity, in reality many are quite intolerant of anyone not embracing their radical views. - Charlie Kirk |
My thoughts too. It might not be worth fixing. But you COULD build your own manifold for about $70. ![]()
The info above (and on the previous page) is correct with respect to the unloader function.
A ball and a spring is a check valve, yes. That ball is NOT a pressure relief, the pressure relief is the fitting with the ring on it. I can see it in your original post. I suspect that the ball is a way to fill in a hole that is drilled as part of the manufacturing process. Put the ball back in, add some hydraulic Loctite and center punch gently around the ball to retain it. The stand back and fire it up. With respect to 'age'. Tap the bottom of the tank with a hammer (a pointed chipping hammer is best) to make sure the tank is not rusting out from the inside. That's how old tanks die. I would not give up on that compressor, it is far better than most of the 'oiless' junk sold today.
As simple as that? I like it.
Question, does the check valve (valve with a ball for air go one direction?) go right before the tank, after all other components? Do I need an unloader? Thanks.
Fat butt 911, 1987 Last edited by rnln; 04-06-2017 at 12:27 PM.. |
I did that last night and pumped it up a bit. This morning, I pumped it up to 120 PSI. It holds fine. I might adjust down a bit, maybe 110 or 115 PSI max for safety.
On tank rust, when I release air from the valve at the bottom of tank, I usually see some rusty (yellowish) water comes out first. If I do it several routes, then it's clear. So, maybe some rust. Thanks Quote:
Fat butt 911, 1987 Last edited by rnln; 04-06-2017 at 12:15 PM.. |
The check valve goes into the tank and lets air in from the compressor but doesn't let it back out. So, come to think of it, this wouldn't work as configured. The outlet to the hose needs to be between the tank and the check valve, or needs to use a separate port directly into the tank. Does your tank have more than one port into it? This switch has the unloader in it. It lets the air out of the pipes between the check valve and the pump so when the pump starts it starts from zero pressure so it can get going.
I see. Thanks. The only thing I see is on the pump, there is a hole and air coming out a bit when it's running
Puny Bird
If your motor is starting up fine without an unloader, then it likely has the small hole in the piston top that acts like an unloader.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
my tank has 1 port only. I can have the check valve above tank and the air hose.
Thanks Quote:
it does. Thanks.
Now, I wonder what that metal ball (which pressed into the hole) is for. Is it really for overloaded pressure as safety feature? If I do not need that, I can just glue/weld it in and be done.
