TPMS Sensor Tools?
Looking for a tool to reset my sensors on a 2008 Toyota Yaris when I change wheels and tires from winter to summer and back.
I can have it done free at the local tire place, but it is a bit of a hassle and usually a wait. I purchased an Autel MaxiTPMS TS401 thinking it would do the job, but nope you have to take the sensor codes and upload through an OBD tool- not made clear when I purchased and not sure how expensive one would be that could do that? Any suggestions on either a OBD unit or a complete unit that reads the sensors and then automatically uploads? I would spend around $200 to avoid the hassle, much more than that I guess I sit at the dealer. Thanks.
Rutager West 1977 911S Targa Chocolate Brown |
Why do you need to know the tire pressure on a Yaris? That thing could probably care less if it had 20 or 40psi. Toss the TPMS and go with standard stems. Problem solved
'95 993 C4 Cabriolet Bunch of motorcycles |
Are you saying that it's not the sensors, but rather the DME that needs to be reset? Like with a PC or software program? Maybe try Foxwell or Schwaben?
Yes, when you change the wheels, you need to read each wheel's sensor and then get the codes into the cars computer for it to work correctly.
The tool I bought will get me the codes from the sensor, but won't upload to cars computer. When they do it at Discount Tire, they point the tool at each individual wheel and then plug the tool into the car OBD port. Motion, the hamsters under the hood require a smooth ride or they bounce off the running wheel!
Thanks Sammy...
...but, reading the question section says that it doesn't reprogram on new wheels, just fixes a weird problem.
Unregistered
Nope, so many of them will just activate or read the sensor, but the car only recognizes them after you enter it into the OBD- if the instrument doesn't have an OBD plug, it only will do half the job.
Thanks for looking though!
Did some searching and I just ordered this one:
https://www.amazon.com/Autel-MaxiTPMS-TS501-OBD2-Reader/dp/B01LRJ7UD2/ref=sr_1_1?ie=UTF8&qid=1493080561&sr=8-1-spons&keywords=autel+ts501&psc=1 Bit more than I planned on spending, although it appears to do a bunch of other stuff too.
76' 911s Signature Edition |
Still Doin Time
My .02. TPM' s send a specific frequency out - the BCM / ECM 'sees' it. Each manufacturer - then each model; their TPM communicates at different frequency. Example- my '08 BMW TPM are 433 Hz. If you want to use different wheels best bet is go to ********. They list the correct aftermarket TPM / frequency for your vehicle. Once installed you will need to go through the OE reset / learn procedure and that's it.
If the TPM' s have been mounted in the wheels for a while - chances are 1 or more will be damaged while removing. So you would need to replace anyway ( ask me how I know) There are programmable frequency TPM's out there ( much cheaper) that do require special scan tools. Those are generally for high volume tire shops.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Still Doin Time
Google - aftermarket TPMS / purchase
The sensors are compatible, it's just that when I switch summer/winter wheels, the car needs to be "told" what sensors to listen for. I just ordered a tool that appears to do everything I need to get the information from the wheels into the car.
Will be here in a couple days and I'll report my success or lack there of. Rutager
Still Doin Time
Unless I'm missing something - if you install new TPMS that has the correct frequency - the vehicle will automatically recognize it, you'll just need to iniate the learn procedure.
Let me know.....
I always thought that the reason to input either snow or summer tires had more to do with calibrating the ABS.
Still Doin Time
No. The TPMS sole function is to 'broadcast' air pressure readings via wireless means to the BCM /ECM. The tire or wheel type or size has no bearing or effect on that.
^ Yes, I understand that. But there is a separate input command to tell the DME which type of tires you are using, at least on my car. The fact that this is not part of the TPMS routine suggests that these are separate parameters.
Fleabit peanut monkey
Had a sensor put in a newer Suburban last week. The guy did something on the dash first and walked around the car with his gizmo. The horn beeped when he pressed a button at each corner. Was that the re-learn procedure or should you be able to do that with the car's brain alone?
1981 911SC Targa |
Still Doin Time
Well I can honestly say - I've not heard of that - ever
The guy was pretty adamant about having to run that procedure with his kit. It did do what it was supposed to do and the sensor worked fine after. I think the effort on the other three corners was overkill. Just one was changed. That's the one that counted.
That was just one car. I don't know much about them. Showboating?
1981 911SC Targa |
I think some cars are able to learn on their own, mine nope, I did several internet and YouTube searches and it all pointed towards needing to upload and that agrees with what I've seen at Discount Tire- guy walks around to each wheel and then plugs the tool into the OBD port.
