-   -   Identify trailer capacity from wheels? (http://forums.pelicanparts.com/showthread.php?t=982332)
dad911 12-31-2017 07:48 AM
I understand, been towing since the 80's. I just don't want to use underrated equipment, which prompted this thread. Don't want to waste time chasing down this trailer if it isn't rated.
tl;dr - have a 10k trailer, sucky ramps, looking for 'inexpensive upgrade'......
cabmandone 12-31-2017 08:40 AM
The C.L. link below is the guy I bought my Load Trail from. His prices are extremely reasonable and if you gave him a call you might be able to get reasonable shipping. Check the price on the 10K he has listed. It's a standard ramp trailer buy you might give him a call and see if he has any old stock tilts available. I bought mine as a new 1 year old stock piece and got a smoking deal on it.
https://limaohio.craigslist.org/fod/d/equipment-trailer-10k-and-14k/6440264907.html
pen15 12-31-2017 10:48 PM
Not certain, but if you are right on the edge of overloading the axles can you subtract the tounge weight from your load? Example, 14k capacity trailer, 4000 lbs empty, 11000 lb load with 10k on axles and 1k on tounge?
Arizona_928 12-31-2017 11:07 PM
Good price on a bumper pull. ^^
Deductive reasoning says yes, but i'm not sure. Example; My gooseneck claimed the 17.5k capacity, yet only had two 7,000lbs axles. 14k axle max. assuming 3,500lbs tongue weight...
dad911 04-04-2018 04:00 PM
Originally Posted by cabmando (Post 9866422)
....... The new 14K 20' tilt deck I have only cost me $5300 with taxes. A ramp type trailer is probably in the 4-$4500 range new so a used one should run you about half, any more than half and you might as well buy new.
I ended up following the same path, thank you for your advice. Picked up a new 14k Sure Trac today with 18' tilt deck.
Sold my old trailer in 1 day on craigslist.
cabmandone 04-04-2018 04:44 PM
Nice! Hope you like it. One word of advice after the winter we have had. If you're planning to load something, do it BEFORE it snows. Once the deck gets a bit of frost on it, it's almost impossible to get a machine up on it. Learned that one trying to load a Bobcat T650 and had to use a brush burner to melt the snow and frost off the deck in order to get the machine to climb the tilt.
dad911 07-25-2021 06:13 PM
Cab- 3 years later I'm bumping this thread to again thank you for your advice.
The tilt trailer was well worth the couple extra bucks.
SmileWavy
