"If it's in the kitchen it's required to be 20A circuit GFCI protected. If the work is being inspected the receptacles would be required to be tamperproof unless they are 5'6" above the floor." It is almost exactly 5'6" from the floor to the edge of the counter, and then diagonally up to the center of the receptacle. At the end of day 2 I have made some progress. The nexus of this project is Mrs WD's desire to move the garbage disposal switch from the right side of the sink to the left side. as well as replace all the ivory colored devices with black colored devices to go with her tile scheme. ![]() ![]() I took out the disposal switch and pulled the wire into the basement and replaced the small steel old work boxes from the last remodel (in 2001) with deeper plastic boxes. I still have to fill the hole next to the box. ![]() There was one receptacle to the left of the sink. Again, I yanked out the small steel old work box and replaced it with a deep 3-gang box. I replaced the outlet with a black one and added the switchs for the disposal and the under counter lights.
. Last edited by wdfifteen; 03-22-2018 at 01:32 PM.. |
I don't see a GFCI outlet in the photos...
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
least common denominator
And I'm like.... sure, but I will have to rip open the wall, run new conduit, and then patch up the drywall.
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
I would be a little concerned about not using a GFI near water. Personalty any bathroom/kitchen on my property have nothing but GFI's in every outlet. On the other hand when you want to sell later it is easy to install GFI outlets.
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. Last edited by scottmandue; 03-22-2018 at 02:27 PM.. |
Platinum Member
Per 2011 NEC (newest I have handy) exemption is 5-1/2' above the floor. Not diagonal across the counter. I believe the tamper-proofs started with 2008 code. If you are swapping receptacles I'm not sure that would trigger a necessary upgrade. However GFI is a good idea and has been required for 30+ years. It' not like a kidd is going to climb on the counter and insert paper clips.
If you had kids or grand-kids, changing the low ones might be worthwhile. I see grounds twisted together.... you do have a wirenut or crimp on that?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
![]() Sent from my SM-G903W using Tapatalk |
You don't need one in every outlet, just one for every circuit. ![]() Look way over on the right. ![]() See it? It's the 1st outlet in kitchen circuit #1 - the one I'm currently working on. ![]() Here is the first outlet on kitchen circuit #2. This was all in place before I started. The room was remodeled in 2001 and was in compliance then. All kitchen outlets are GFCI protected.
. Last edited by wdfifteen; 03-22-2018 at 03:17 PM.. |
You are correct, sorry I misunderstood. Thought you were removing all GFI's, didn't know you were daisy chaining off the main GFI.
Brew Master
Yes, crimp collars. They were big and wouldn't work without a fat wire bundle to go around. Its all i had.
When they remodeled in 2001 they used small steel old work boxes, the kind with the steel straps that you bend over. All of the box extenders I've been able to locate are for boxes that are 1/4 inch taller than these. I can modify them I guess, but the extenders are $1.44 each and new deep plastic boxes are $1.89. Guess I'm going to replace all the boxes. The new boxes have screws long enough for 1/2" drywall and I'll have drywall plus the thickness of the tile, so new, longer screws will be needed. Amazing how a seemingly simple job can cascade into such a time and money suck.
