Originally Posted by GWN7 View Post
Cost of labor for a simple deck is usually the same as the material cost. So if your material is $1,500.00 your labor is $1,500.00. The prices go up for steps, compound angles or if you live in California.
I've heard this frequently and don't understand it. Say you select materials that are the same in dimension but 20% more. Why isn't the adjusted bid $1,800 and $1,500?
Sold: 1989 3.2 coupe, 112k miles
Old 06-28-2018, 08:38 AM
biosurfer1's Avatar
Often times it can be because sometimes the more expensive material is harder to work with. Ipe and a lot of the SA hardwoods, it's recommended to pre-drill before any screws are put in. They also sometimes require (or highly suggest) stainless steel hardware, etc.
1992 968 Polar Silver
2010 Toyota Highlander SE
2006 Lexus LS430 ML
Old 06-28-2018, 10:56 AM
Counterclockwise?
I hate it when my wife pulls that s##t on me too.
Great job!
Rod
1986 Carrera
2001 996TT
Old 06-28-2018, 11:17 AM
GWN7's Avatar
biosurfer1 hit the nail on the head (so to speak)
Plastic decking is all the rage here. It has hidden fasteners that hold the bottom edge of the decking down and then the next piece is also held by it. PIA to install, but looks very nice. Takes 3X as long to install against a typical wood deck (2 X 6 or 5/4ths) but the material is more expensive too. So the formula still stands.
Anytime I have done a deck for someone I collect 1/2 the day I start and the second half when I'm done. That way I always get paid for my materials. Never had to worry about the second half.
Bunch of old cars
Old 06-28-2018, 08:26 PM
Don Ro's Avatar
Finally done - finished the last bit of the path on Sunday.
Expense breakdown:
  • Prep, including having the old patio removed, french drains, etc: $2100
  • Framing, including piers, joists, hardware, drainage gravel,etc: $2300
  • Decking: Grade "B" redwood & screws: $2800
  • Finishing, including stain, repairing damaged sprinkler lines, electrical, new path edging, pavers & rock, etc: $2400
Soup to nuts, everything came in a little under $10k
You do good work, Mr. On the hardscape too. Quite nice!
My simple Redwood deck...took me well over a month to complete.
First pic is after a rain.
Second pic is sanding after 10 years...(just prior to selling). Then treated with Cabot's clear.
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 06-29-2018, 03:08 AM
FPB111's Avatar
My sisters 24x14 synthetic board deck with 6 steps down to an 8x8 landing with 6 more steps to ground cost $17,000. This included demo of the same layout in rotten wood a new ledger board and eight concrete piers with wood posts.
It was done by a crew of fireman who moonlight.
I thought that was expensive but after looking at it not so much. It is really quality construction.
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 06-29-2018, 06:37 AM
GWN7's Avatar
The guy who I worked for building decks and fences company was called "Moonlight Fences and Decks"
Bunch of old cars
Old 06-29-2018, 10:26 AM
