3M Air Fed PAPR Mask (Weld, Grind and Paint) Versaflo VS Jupiter VS Adflo
Hi,
Anyone specifically using the versaflo or jupiter 3M air fed (PAPR) battery powered belt systems with the 3m 9100 series welding helmets? A bit specific, i know! Apologies. I'm looking for an air fed battery belt system. I can see that 3M sell the 9100 welding headgear series, which is aimed at the "adflo" belt system. Ideally I am looking for a belt system, that I can use for welding, grinding AND painting. I like the 9100 and the 306 but it does not have to be this combination. The 3M website does not really discuss the Versaflo system (besides the compressor version) with the 9100. The 2016 launch pack does, https://multimedia.3m.com/mws/media/1266424O/9100-series-with-tr600-product-announcement.pdf As does this 2020 document for the Jupiter, https://multimedia.3m.com/mws/media/1420267O/3m-jupiter-powered-pdf.pdf but this is all I can find...there is no mention of it on the website Anyone use this system? Luke Last edited by strictly; 03-07-2021 at 12:06 PM.. |
Safety glasses for grinding, crack the door for mig, outside for stick, tig no bother and a throw away respirator for paint. It looks like a nice system if you can afford to spend the money only problem is you can’t enjoy a smoke while you grind your welds.
