Need part nymber for interior trim
You can see the lower interior door jam trim needed. both sides of whatever trim and backing needed to replace. Part Number?
Thanks! http://forums.pelicanparts.com/uploa...1725908046.jpg http://forums.pelicanparts.com/uploa...1725908046.jpg |
No part number for that
That is part of your carpet. Only comes on full carpet kits Try an upholstery shop to make you the cut |
ok thanks
Or mask the whole area and paint it with black upholstery paint.
Duplicolor vinyl and fabric. It would look better for sure |
you think spraying w/ Duplicolor would be better than tryng to match color and texture with a pieces fron an upholsterer?
never used it. |
Paint is cheap
If you don't like it you can always go upholstery route Put a WTB add for the pieces. Some pelicans buy the carpet set for other areas and have some left overs You never know |
right!
| All times are GMT -8. The time now is 06:05 AM. |
