Cleanup after Media Blasting
My 914 is coming back from the media blasters in a coujple of days. Glass and Soda. Excellent work with no warping. Now. What's the best way to clean up the body before applying undercoat? Soap and Water and an Air Hose? What works good and are there special solvents/cleaners that I need to get? Thanks Bill
Wouldn't water start the rusting process? I would guess air, vacuuming then mineral spirits. I am anxious to see what the others answer because I need to prep my metal too. Good luck!
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
abit off center
I would just blow it out with a real good leaf blower then wipe it down with some solvent.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
go read the sticky at the top of this forum. Freddie gives you a good explanation of how to prep a bare metal panel. He uses PPG products.
Robert Williams 70' 911T |
Freddy's work
I read Freddie's techniques, but they're geared to a hood on saw horses. What about the dust and crud down inside the engine compartment and in the tunnel? Actually, a leaf blower doesn't sound like such a bad idea>) for the dust.
I'm thinking about using something like Eastwood Prep in a garden sprayer, the leaf blower, more Prep spray and a final blow out for those parts...and a normal wipedown cleanup for the flat surfaces. Any other thoughts out there? |
