Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Taking care of surface rust appearing (since sandblasting) prior to epoxy priming
Although I wanted to epoxy prime everything shortly after I had my body sandblasted, things don't always work out nicely. I was able to get the chassis primed, but my fenders, and hoods did not get primed and have sat around and I have noticed a bit of surface rust appearing here and there, particularly around patches I had welded, but I also saw some in the general surfaces as well. Does anyone know of a good product to take care of this sort of surface rust prior to priming? I've heard that washing with sulfuric acid will take care of it, followed by a water rinse, but it would seem to me that that would cause another case of flash rust to appear.
Geoff
'82 911SC (Complete rebuild)
Click here to go to the project website that chronicles the rebuild process
Old 06-22-2008, 10:33 AM
3.2 CAB's Avatar
I would not use Sulfuric Acid on the panels. A few different products on the market will take care of just light surface rust, and not really harm the surface like Sulfuric Acid could. Some of the products can even have a very mild phosphoric acid content, and are made for this type of application, and will readily remove the surface rust with very little effort without possibly damaging or contaminating the "fresh" metal surface. PM me if you would like to discuss some of the different products. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 06-22-2008, 10:43 AM
3.2 CAB's Avatar
Geoff, I answered your PM. Tony.
Newest additions-
others...
Old 06-22-2008, 04:10 PM
Tim K's Avatar
This is in the sticky at the top of the Bodywork forum
http://forums.pelicanparts.com/showthread.php?t=262049
Here's the link to the rest of fhernand's articles:
http://forums.pelicanparts.com/showthread.php?t=381243
Good luck!
Old 06-23-2008, 12:17 PM
Tim,
I've read these before but forgot the metal prep/epoxy priming one dealt with this issue (Hey, I'm getting old). Thanks!
Geoff
Good luck!
Old 06-23-2008, 04:21 PM
rw7810's Avatar
PickleX is a good product for this. Go here for info: http://www.autobodystore.com/forum/index.php
Robert Williams
70' 911T
Old 06-24-2008, 10:04 AM
bandjoey's Avatar
Metal Wash
I'm 2 week in from media blasting and waiting on sheet metal I want to weld in before I undercoat. Sprayed on Eastwood metal wash. Comes in pint can, mixes gallons with water. So far just a few spots of surface rust on the fenders from handprints. Those I sanded down and sprayed again. They advertise up to 3 weeks protection from flash rust. I'm impressed.
Old 06-25-2008, 05:12 PM
Actually, I'm about 2 months now since sandblasting and it is only areas that I have welded or, like you had original fingerprints from the sandblaster (not sure why) that are showing surface rust. The general areas are not showing rust - there may be some there that I'm not seeing, tho. I'm going to wash it down with one of these metal prep solutions (like the Eastwood one) that contain phosphoric acid before I epoxy prime.
Thanks for all your suggestions.
Geoff
Old 06-26-2008, 04:31 AM
Ok, I ended up using PPG DX589 and DX520 metal conditioners. I just want to check with you experts to make sure that this fender is looking like it is supposed to (pretty ugly). I expected to see the hazy zinc phosphate look, but not the rusty orange patches. I suspect that these are iron phosphate, not iron oxide, tho. I prepared it as per the PPG instructions - DX589 1st followed by a water rinse. This produced pretty much what you see. The DX520 treatment after didn't change things much. Is this what it is supposed to look like? There was very little surface rust, before this metal prep treatment, but now it looks like its all over the place. Can I assume that these orange patches are not rust but is harmless iron phosphate that can be primed over?
Thanks.
Geoff
Old 06-30-2008, 04:31 PM
