Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
First-time body work project . . . advise please
I've noticed the under body on my 69E has taken a beating over the years from ill-placed floorjacks/jackstands. So the area of interest is right under the torsion bar/spring plate mounting location where the metal has colapsed about 1/4 to 1/2 inch. Since this looks to be impossible to access from the other-side which means I can't just hammer it out . . . it seems that I need a dent puller/slide hammer to remove the dent. So my list of questions are . . .
Is a dent puller the right tool for the job?
If so I need a welder for the draw pins, which welder would be best for this simple job? (I've never welded before)
Can someone recommend a 'dent puller' kit for this job?
Cost of these tools is a factor . . . I just need something that is good enough to do this job and satisfy my interest in learning a little bit about body work.
Thanks for your feedback,
Tom Ching
69 911E
Old 07-07-2008, 04:42 PM
It is probably rusty behind the dent.
Old 07-07-2008, 07:25 PM
Ok, but there are no signs of rust anywhere near the area and the indentation (dent) is very solid.
Help me understand why it would be rusty?
BTW, do you have any advise/suggestions regarding my questions? I could use some experience here.
Regards,
Tom Ching
69 911E
Old 07-07-2008, 08:03 PM
robmog's Avatar
tom
that is a common area for rust to form,
especially if your rockers have holes.
if you've stripped the undercoat and see no rust its probably ok.
aside from cosmetics, why do you think its necessary to fix?
you can get a stud welder for about $100 on ebay, often it will include the slide hammer
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 07-08-2008, 09:20 AM
Yeah . . . if it ain't broke . . .
Your right, pulling dents out of the undercarriage it rather dumb. But my thinking is that it would be a great opportunity to learn a little bit from doing some body work. And best of all, it's not in an area that I have to worry a bit about the finish and it's not like I can make it any worse than it already is.
So a stud welder will do the draw pins . . . and then the slide hammer to pull the dent.
I think I can do that.
Any recommendations on a stud welder?
Thanks,
Tom Ching
69 911E
Old 07-08-2008, 09:14 PM
robmog's Avatar
here you go.
http://www.eastwoodco.com/jump.jsp?itemID=1609&itemType=PRODUCT
bob
1972 E pos
someday....
Old 07-09-2008, 03:55 AM
Hey Bob . . . thanks for the help.
I'll check that out.
Tom Ching
69 911E
Old 07-09-2008, 06:54 AM
BReyes's Avatar
May want to post a pic. Did you know sometimes a tool that resembles a T handle with a small bend at the tip works without needing to use a dent puller. Drill 1/8 hole insert the little tip with the bend and pull the dent, weld up the tiny hole and prep.
Regards,
Bernard
Old 07-11-2008, 07:18 PM
DP935 member
kycarguy 935's Avatar
Harbor Freight makes one also for around $100.00. Not sure of the quality but the case looks like the Eastwood model except HF model is yellow.
I just looked and it's on sale right now for $94.99 on page 12 good until 7.21.08
http://www.harborfreightusa.com/usa/tabviewer/startBrowseBook.do?bookid=212&preview=&type=RET&si mple=
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 07-11-2008, 09:54 PM
HF is a great source
I would never thought HF would have such a tool.
I'll check them out . . .
Will also post some pic's of my progress as soon as I can.
Right now I'm just getting the car back on the road again after a motor/trans/suspension rebuild. Really anxious to just drive the car again after a 3 month project.
Thanks for all the help.
Tom Ching
69 911E
Old 07-11-2008, 11:46 PM
(the shotguns)
berettafan's Avatar
HF is exactly the sort of place i'd buy a stud welder.
keep in mind you'll have undercoating to replace if you do any welding under the car.
Old 07-23-2008, 07:21 PM
