-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/forumdisplay.php?f=270)
-   -   Cost for front pan replacements? (http://forums.pelicanparts.com/showthread.php?t=469305)
euro911sc 04-16-2009 11:02 AM
Cross post on 911 forum:
http://forums.pelicanparts.com/showthread.php?t=469256
I am looking at getting into a heavy restoration project on an early car (pre-galvanized). I've been scouting several candidates and they all need front pan work and usually pedal box work. Now, I can weld... but for this project I will be farming out the welding work as I need this to be good http://forums.pelicanparts.com/ultimate/tongue.gif
What are others experiences on the cost to replace the front pan and, separately, the pedal box?
I have also considered doing my own fitment and calling in a traveling welder to do the welding, but where the suspension is concerned I'm thinking I want that to be spot on to reduce any probable handling issues.
Thanks,
-Michael
Jagshund 04-23-2009 07:41 PM
I would recommend doing it yourself. It really is a . . . um . . . unique experience. Buy about six spot-weld removal tips from a reputable source and go to town. Since I was taking out the longitudinals, I put in some .045 supports to keep the chassis square (pics here). In all honesty, I did use a plasma cutter in the pedal box but could have just as easily used a sawz-all.
As for the suspension pan, I would gain access to some sort of jig or be very careful when tackling that. There was a couple of guys in May's Excellence that did it on their own; a couple of years ago they had a site documenting the entire build. I'll see if it is still up and post it here.
