Bottom of the can of Rage
I'm getting to the bottom of my can of Rage. Theres a gold varnish looking liquid sitting at the bottom under the filler. Should I avoid it, or mix it in?
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor |
dkbautosports.com
you should throw the can away and open a new one . when ever you open a can of body filler you should mix it up and that goes for every time it sits for more than a day or two .
Thank You, that's what I was thinking. But I wanted to make sure.
dkbautosports.com
when ever your uncertain about a product like body fillers or primers that may be bad its best to just throw it out and open a new can . it would realy suck if you tryed to use it and you get the car into paint and then have the product fail down the road .
Fleabit peanut monkey
I am using Rage Gold now. I warm it up in a tub of water as the garage gets down to 50 at night. Mixes fairly easily after it softens up.
In a hurry I bought a can of just Rage regular. Don't know if I'll like it.
Let us know. I have not used the extreme only the gold. Assuming regular is not the gold. The gold works easy.
Works ok. I'm a little worried about pinholes. We'll see.
dkbautosports.com
in my shop we use USC pro 7 body filler . for the last skim coat of plastic we also use a very light wieght body filler called icing its also made by USC . its sands real ez and is made to fill any little pin hole or sand scratch that primer will not fill .
Icing is great stuff but you have to squeegie it in real good and flat or it can be a bear to sand down - especially when you are using 400 or thereabouts.
I also use it for tiny dents. Tube says 1/8" max but I never go that thick for filling an imperfection.
dkbautosports.com
unless you have primed and have the panel ready for paint and then find a pin hole that you need to fill you should not be wet sanding it of sanding it with a grit less than 220 . most primers will not bite into a cut less than a 220 very well . a 320 cut would be the very least you want to apply a primer over . when your spot priming you want to do your back sanding with a 400 to 320 grit but thats only for the primers over spray edge to have some thing to stick to that gets sanded back at a later day when your preping the panel for its top coating . with a light filler like icing you can knock down the spreader marks/lines with a 180 paper then go right to a 220 paper and then do your back sanding around the area were the filler is with a red pad or 400 to 320 paper blow the panel off mask for primer then do your priming .
What do you mean by "Back sanding"?
My basic steps are to hog with 36 and shape with 40. Final sand before primer may be as high as 220. I will use Icing before primer but after primer you find little surprises and I use it again.
Here is where you will probably teach me something. I never touch primer with anything but wet sanding unless there is a screw up. I have applied Icing over the primer and then tried to use wet sanding paper and that is where the problems come in. Edit - I read you post a little closer. I think the problem is the "applicator" (me) . Too much at the wrong stage. Last edited by Bob Kontak; 02-12-2011 at 07:43 AM.. |
