-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/forumdisplay.php?f=270)
-   -   Help!! (http://forums.pelicanparts.com/showthread.php?t=589072)
vwbobd 01-31-2011 04:20 PM
Help!!
well , long story short: I ended up firing my body shop for long delays and lies. Found a much more reputable one and am preparing to take it to him. I was going to install my door strikers so they would have them to get all my gaps and panels fitting properly and I discovered that it appears the other guys flubbed up on installing the striker posts. the strikers sit way lower than they should and the door sits perfect. I need two measurements form you experts so he will be able to get this back where it belongs. In the included picture I need the measurement from "A" to "B", and if it is not too much trouble a level measurement from point "B" to the door hinge post . Thanks guys I really have a big headache since I discovered this :mad:. I was so excited to get this thing painted and now im in for two more striker post and labor :mad:: This is not my car , but a gorgeous example I found on Pelican.
[IMG]http://i47.photobucket.com/albums/f1...seyplaid02.jpg[/IMG]
962porsche 01-31-2011 07:15 PM
if the door is on the car and you have the gap the way it should be to the QTR. it being a smaller gap on the bottom of the door to QTR and just a little bigger on the top were the door meets the QTR . then you move and clamp the striker post so the door closes the way it should with the door gaskets installed . when its right you pull the gasket back out then weld it in place . there are no chassis measurements for what your looking for because no two cars are the same . you will find they are 5mm off from car to car with no set dimensions .
vwbobd 02-01-2011 03:04 AM
Thank you, I was thinking along the same lines. So I guess I should not panic . I will just get replacement jambs and just have it done by setting up the door first. I appreciate your help my good man. SmileWavy
pontifex4 02-01-2011 09:12 AM
I can't help, but those seats are things of beauty!
