Body Panels compatability
I have an 88 930 coupe and was curious to know if all 911 doors are compatible from 1980 - 89 year model. Can a door from an 85 carrera fit onto a 88 930? Or is Carrera doors different from 930 doors? And different from year to year?
Thanks, Sean |
I know I'm having slight issues fitting 73 fenders on a 86 body. Not super hard but you can def tell the earlier cars were hand fitted. Curious to see what others chime in on the later cars.
dkbautosports.com
from what i have found over the years is that the doors are like this 1985 and 1986 . are the same .
1978 and 1988 1/2 are the same . 1988 1/2 and 1989 are the same . most of what you find are deferent is the things on the inside of the doors and how they bolt up . because the 911's are hand built cars even if you take a part from the same year car there is no guaranty it will fit or just bolt right up and be perfect . you also have to hand fit and build the car when you work on them . |
DP935 member
How about sunroof clips? I have an 87 that will need a sunroof clip. I had a 68 that needed the sunroof replaced about 24 years ago and ran into all kinds of trouble.
962porsche would you know which are interchangeable? Thanks.
Porsche Slantnose M505 M506 group on Facebook. https://www.facebook.com/groups/719995181372494/ |
