Remove undercoat...or not?
Got the 1978 SC almost ready to get media blasted. I am just in doubt if I should take the effort removing the rubber undercoat. It is still in relative good shape and I will never be able to reproduce a good protective layer as the original undercoat.
However, I like the idea of starting with a clean tub. At the end it will be a street and occasional DE/Track car. Maybe more tracing in the far future. What was your guys motivation of removing the undercoating? http://forums.pelicanparts.com/uploa...1386539767.jpg http://forums.pelicanparts.com/uploa...1386539787.jpg |
I would not remove the undercoat on this car it look to good .I do remove Undercoat 65-77 because most time i find rust and have to do welding .
If the chip/stone gaurd is still good leave it alone. On the other hand, are you paying by the sqft?:eek: Maybe just do what needs to be removed if any.. have them feather the edges and reaply new chip/stone guard. Check out past threads there is much info.;)
i did a full media blast on my '75, when it came to the undercoat section, I asked the plastic blaster to just do a once over lightly on it unless it came off easily or if there appeared to be a problem.
They complied, there were one or two spots they blasted off, but for the most part it left a very nice, somewhat fuzzy surface that I put the Sikkens OTO chipguard on top of. That was close to 20 years ago....and it is still fine, no issues anywhere.... Dennis |
| All times are GMT -8. The time now is 08:31 PM. |
