1982 930 Paint Code
Hello,
I'm new to this forum, and need your wisdom to find out the exact paint code for a black 1982 930. Hopefully the original paint was black too, I'm not sure. I have the VIN number if helps at all: WPOZZZ93ZCS000057. Thank you for your help! |
The quickest easiest way to get the correct info is to give the local dealer a call.
the code should be on the front part of the drivers or left door jam . look for one of two numbers .
it would be 041 or 700 . |
81 to 83 SC had the paint decal on the inside trunk area of the passenger frt fender maybe the 930 is similar
Lorne M |
| All times are GMT -8. The time now is 02:50 AM. |
