Spray Paint removal?
I have an inlaw who's car was vandalized with some spray paint. Any suggestions for safe removal without damaging original paint?
Ed 1973.5 T |
non-whiner
Auto paint reducer will take it right off.
"Too much is just enough." |
dkbautosports.com
spray can spray paint has no hardener /catalyst in it so there are a number of solvents that will remove the spray paint and not damage the cars OE finish.
because of cost I would not go right for the automotive grade reducer . I would 1st try good old paint thinner you can get a gal at your home store for 15 dollars . is you need some thing a little more aggressive you could go with acetone . once you remove the spray paint you will probably need to polish the areas that were sprayed and cleaned . the solvents will take some of the shin off the OE finish but it's nothing you have to worry about . you should always do a little test area 1st to be sure the OE finish will not be damaged by any solvents you pick . needless to say wear rubber gloves when working with any solvents . you should also use cloth rags and not paper towels things like old tee shirt rags work good . |
Thanks. I'll give the paint thinner a test on a small section first.
Ed 1973.5 T Last edited by E Sully; 12-22-2015 at 04:59 AM.. |
