Turbine HVLP Paint System questions
Anyone here on the board ever used one of the newer Turbine HVLP paint spray systems to paint their car. Considering buying but need input along with recommendations on best systems to consider. I've painted my own cars in the past with conventional air compressor systems but have heard several people talking about these newer systems. Any info? Thanks Bill
sorry i don't have a new one mine is over 25 years old .
i will have to say i used it with very good results . from time to time i still use it i painted a 26' car trailer with it this spring for a friends in his warehouse as the trailer couldn't be moved with out axles . sprayed limco 3 single stage out of it used a 1.3 tip ( it also has a 1.6) laid down like glass other then spraying in open air getting some dust in the job it looks great . side note . last year i bought all the equipment for doing vinyl graphics and wraps i wanted to wrap the trailer but he wanted it to match his tow rig's color and vinyl can't do that . i did do all the lettering and graphics in vinyl so it does hide the few big dust nugs that was in the finish . |
Adidas - I have been thinking about painting DIY job - I came across this article. I was looking at the fuji sprayer. Not sure if anyone has experience with any of the makes shown
http://www.fujispray.com/Fine%20Woodworking%20Article%20-%20SprayforLess%202014 |
I found threads on another site where people reported excellent results spraying glasurit. I've considered this route myself because a compressor takes up so much space.
Note that I have not tried it. Here's what I've found: Air comes out warm and dry Operates on 110 Extremely small units Four stage turbine is recommended More reducer is suggested Loud Is basically a vacuum cleaner motor (you can make your own housing) Spray at a distance of 4-8 inches Uses much less paint due to less overspray The only reason I haven't invested in this is a compressor will run a blast cabinet and that might be really nice. |
I was strongly considering one of the Fuji turbines for painting - seems a great way to paint at home with less overspray and without an elaborate moisture-control system with a compressor. In the end, I decided to stick with a compressor-based HVLP gun, because I needed a larger compressor for bodywork/blasting anyway. I also found a lot more online help pertaining to compressor guns rather than turbine guns (for example, all the tech sheets seem to be set up for traditional HVLP guns). The downside is implementing a solid moisture control system, but I figure the compressor is something I'll use for many years to come, so I'll want to preserve my tools anyway.
I know this thread is 3 years old by the date stamp on the last post.
That being said, anyone have any updates on experience. I have been reading up on the Fuji line and this look promising. Looking at one to paint the 912 projects, a friends plane and car, house exterior and cabinet stain. Thoughts?? |
I've been in the finishing industry for over 45 years.
Used every conceivable spray rig and coating available. I've painted well over 1000 cars, and later started a cabinet refinishing business. An HVLP spray gun using compressed air started being the only allowable system in Calif. way back in the early 1990's, due to environmental regs. I currently use a turbine sprayer with delightful success in most cases. Where it isn't recommended is in a very hot climate. I recently was contracted to work on Maui, and had some ceiling panels which required spraying catalyzed conversion varnish. Since the residence was already occupied, the only place available to do this was outside under an awning when the average daytime temp was north of 90 degrees. The heat developed by the HVLP unit coupled with the ambient temp made achieving a flawless, properly flowed out finish impossible. So it pays to have a pneumatic rig for this kind of situation. |
I have an Apollo HVLP system that i have not used to spray automotive finishes yet but plan to test.
Dollar for dollar a compresser vs turbine HVLP setup which is a better deal? I'm thinking about re-spraying my cabinets.
at our home I have a smaller compressor it's fine for my home as I have a very big compressor at my shops. but at home my compressor will run out of air after spraying something the size of a QTR panel or a fender so I also have a turbine spray system. I don't do much painting at the house because I have a booth's at both shops. I am a believer that having as much air supply as you posable can is always the best. the reason is because then you can also run so many other air tools from it. I know full well about the limits of some home shops being able to even have the electricity to even run a bigger compressor. this is the case with my garage at the house. it's a 5 car detached but being it's a 1900 house and garage that was a carriage barn I'm limited on electric power in the garage. to get more electric into the garage I would need to tear up a good part of our brick driveway. not happing! |
| All times are GMT -8. The time now is 05:29 AM. |
