Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
plumbers abs plastic pipe glue? or acetone to weld plastic
which is better to weld back broken abs plastic?
https://www.youtube.com/watch?v=QYniBuNNOA4
https://www.youtube.com/watch?v=2YIV0XVkkPE
Old 04-04-2018, 08:42 PM
Old 04-09-2018, 09:47 AM
dkbautosports.com
962porsche's Avatar
i have tried it a few times it's fine if you don't mind seeing the line of the crack thru the new paint.
it's all about how cheap you want to be with the repair and how picky you are about how it looks when your all done with it.
Old 04-09-2018, 11:56 AM
would do body work after of course. just looking for a real good strong simple bond
Old 04-09-2018, 12:40 PM
Retired Member
Brian 162's Avatar
Depending the size of what you are bonding. I used a soldering iron to repair a tab that broke off a headlight housing. It worked. It 's hidden by the fender so I didn't care what it looked like.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 04-09-2018, 07:14 PM
Fleabit peanut monkey
Bob Kontak's Avatar
PlioGrip makes a two part adhesive "kit". A little spendy though.
Suspect the full compliment of gear in this video will push $200 not including air tools.
This repair is on the real good, real strong side but by no means simple. Just for hip pocket info.
https://youtu.be/N2oKuRQEzdc
I have not used this but have used their panel bonding adhesive. It has way longer work time than a minute or two like this plastic repair kit. I don't care much for that. However cure time is under an hour compared to 24 hours like the panel adhesive.
1981 911SC Targa
Old 04-12-2018, 10:56 AM
