-   Porsche 356 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=6)
-   -   Proper way to lift up your 1964 356 (http://forums.pelicanparts.com/showthread.php?t=1043127)
356cee 10-20-2019 08:15 PM
Just recently purchased my first 356. Am excited to learn more about my car. But first off, I need help on learning the proper way to lift my car. From what I can gather, the rear can best be lifted by the transmission bracket with a floor jack. The front..lift at the diagonal area. Please advise.
Thank you in advance
Pics would be better if you have any
930cabman 10-25-2019 05:14 PM
I have used the engine at the rear and axle beam at the front. AS far as I know the entire 356 weighs around 2,000#
Bunka 10-26-2019 09:12 AM
It is my understanding that the transmission bracket, or hoop, is a good strong place to lift the car in the rear. That is the place I have used for over 52 years. I'm not sure about the "axle beam" in the front. That may be in reference to the tubes for the transversely mounted torsion bars which are just straight springs. The front suspension is made up of dual trailing arm links with an anti roll bar mounted transversely. There is no axle in the front, however, the torsion bar tubes are also very strong points for lifting. I have also been comfortable with lifting the car at other various points using a piece of wooden 2 X 4 to spread the weight bearing over a much bigger area.
wdfifteen 10-29-2019 03:57 PM
The transmission hoop (I assume this is what you mean by bracket) is a great place to lift the rear. Don’t lift it by the engine. Jack it up with the hoop and support it with jack stands under the rear torsion bar tubes.
At the front, lift it with the jack under the lower torsion bar tube. The front anti-roll bar is right in front of it so the jack will catch it too. Don’t worry about that, you won’t hurt it..
bleucamaro 10-30-2019 11:57 AM
More important is how to close the frunk (front trunk). Never pull down. Always disengage the holder by pushing back up. Same goes for the rear hood, but its stubby and less prone to pull down damage.
