turn signals
Hi,
How do you remove the turn signal lense to replace a bulb. does the entire assembly need to be romoved or is there an easier way? thanks |
I've only had to replace bulbs in back , and the lens comes off, as does the chrome ring.
Thanks - I figured it out - they screw off - mine just had a bunch of sealer holding it down tight!
| All times are GMT -8. The time now is 11:11 PM. |
